Read abs codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chico, Dec 13, 2019.
  1. chico
    chico Junior Member
    Ontario Canada
    I have abs lights on my dash.
    I'll try the paperclip trick that I found a YouTube video of but I have an ODB reader and I can't get anything from it. am I supposed to be able to read these codes from an ODB reader or do I need something special?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    You need an abs scanner to see which wheel bearing is bad
  3. ChapmanF
    15,571
    Most OBD-II scanners should be able to show you most of the brake system codes (though not necessarily tell you what they mean). The jumper-wire (or paper clip) approach where you count the light blinks has also been described in a lot of threads here on PriusChat. Wheel bearings are far from the only possible root causes ... the codes will indicate what problems to look for.
  4. chico
    chico Junior Member
    Ontario Canada
    Hmmm when the warning lights are up in the dash and I run diagnostics withwmy odbll it says 'no errors'
    I have an ELM327 and the app 'car scanner' which asked for the model of car... So I assume it had specific prius gen 3 codes
    Do different apps have different readouts? I know people like torque pro, but I don't know why :/
  5. ChapmanF
    15,571
    I'm not sure which ones are better than others ... I would expect more of them to have less trouble reading more of the codes, but a lot of them seem to have problems. Techstream eliminates the guesswork.
    You always have the option of getting your (abridged) codes by the count-blinking-lights method, which can at least get you started understanding what's wrong with your car, while you're still solving the better-scanner problem.
  6. chico
    chico Junior Member
    Ontario Canada
    So years ago this problem disappeared when I removed my ODBII scanner. Apparently some of the scanners cause issues. I was hoping that was the end of it but now it's back again.
    The car seems fine, but I have brake warning lights, red warning lights, ABS Lights, slip indicator and tire pressure lights all on at once :(
    T_T
