Read data from canbus.
Discussion in 'Gen 4 Prius Technical Discussion' started by Alleg, Jul 28, 2021.
  1. Alleg
    Alleg New Member
    Modena
    2019 Prius
    Active
    Hi everyone, I decided to ask on this forum because I can't find any good info on the internet.
    I am building a simple display to look at mg1 mg2 torque/power and some other interesting Infos.
    I am using a simple teensy board with a canbus transceiver.
    With a simple program I can see all the traffic on the canbus, I've tried on a Lexus ct200h and saw everything like a Prius 3, but on the Prius 4 I can see only a few messages, tried on a rav4 2019 same, ux 250h same.
    Seems like a firewall for the broadcasted info is kept internal.
    Someone has some suggestions, I'll post a photo of the output asap.
    Thanks for your attention.
  2. Alleg
    Alleg New Member
    Modena
    2019 Prius
    Active
    This is what i read from normal canbus, in the second image is what I'm sending without a response.
  3. ihatenoise
    ihatenoise Junior Member
    Toronto
    Are you seeing other CAN messages? You should be at least seeing all the messages described in this dbc opendbc/toyota_prius_2017_pt_generated.dbc at master · commaai/opendbc · GitHub
    If not, maybe you are not looking at the right CAN bus?
    I never messed around with my car so I'm just guessing... And maybe the message definitions have changed too for TNGA Hybrid cars vs. non-TNGA (Gen 3) for the hybrid system. Seems like no one has really figured out how to get MG1/MG2 information Gen IV Prius Custom PIDs for Torque app | PriusChat
    PtPri likes this.
