Reading Codes on 1998 Gen1 Prius?
Discussion in 'Generation 1 Prius Discussion' started by Stokie, Apr 8, 2016.
  1. Stokie
    Stokie Junior Member
    New Zealand
    1998 Prius
    I
    I talked to a guy from the Battery Clinic who have lots of experience on Prius, He told me it is very hard to find a code scanner for these cars, as they are not OBD2? Can anyone please shed some light on it?
    I have a basic Autel MaxiScan (OBDII/EOBD) scanner, it plugs into the port but it won't read the codes.
    I'm getting a warning triangle beside the speedo and a red car and arrow through the middle icon on the bigger screen.
    The battery has very little capacity - charges up and down very quickly.
    After a drive I get an oil warning light occasionally too.
    And my shift selector doesn't engage the parking pawl.
    Any help gratefully received.
  2. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    So, presumably, you have checked the oil and topped up as necessary?
    What does the OBD (onboard diagnostic) port look like? Any chance of a photo?
    You have what Kiwi refers to as a Gen 0 (zero) as these cars were never officially released outside the JDM (Japanese domestic market). The Gen I was manufactured from 2001 - 2003
    Where abouts in NZ are you? Auckland?
    PS: Did you join the Yahoo! group: Mk1 Prius (Japanese export) global owners group that Bob Wilson and Patrick Wong pointed you to in your last thread?
    #2 dolj, Apr 8, 2016
  3. Stokie
    New Zealand
    1998 Prius
    I
    Hi Dolj,
    I'm in the Nelson region.
    Hmm.. Gen 0... That explains why so many forums on the Gen 1 didn't make sense.
    Here's the OBD port, see photos.
    Thanks.
    Yes, the engine oil was about 6mm high above the full mark on the dipstick - perhaps it expands when hot and goes over a max level limit?
    Are there any other oil locations that would set off an oil warning on the dash?
    Thanks.
  4. dolj
    dolj Senior Member
    8,631
    4,385
    Oh, I was thinking it was low.
    I don't know if the Gen 0 is the same, but other Gens don't like the oil high. I'd try and remove some, so it was at the high mark or maybe a mm or 2 below.
    I'm not at all familiar with the Gen 0, so can't answer your the questions.
  5. Stokie
    New Zealand
    1998 Prius
    I
    Thanks for the suggestion. I've tried to join but something strange is happening with my password / login. I'll keep trying.
  6. Patrick Wong
    18,210
    6,517
    Not only hard to find - impossible. The original NHW10 Prius sold only in Japan used a diagnostic system that does not comply with industry standards.
  7. Stokie
    New Zealand
    1998 Prius
    I
    Yes I finally got it sorted and accepted.
    bwilson4web likes this.
