ready to cry
Discussion in 'Gen 3 Prius Main Forum' started by conniem, Feb 21, 2012.
  1. conniem
    conniem New Member
    Dayton, Ohio
    I just bought a Prius III. Test drove several including a used 2009, V, and a few II's and III's so I felt I had done my homework. I tried to drive over rough roads on my test drives since the roads in my area are bad but after driving my new car twice I'm ready to cry. My ears hurt from the drone of the vibration. It's like when someone's bass speakers in a car around you are so loud it hurts your ears. I'm ready to cry. I was so happy to buy this but what do I do with a car I can't drive. On smooth roads it's not a problem but after a few minutes on even slightly bumpy roads I can't handle the pain.
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Return it. Usually there's some sort of period (150 miles/3 days) for you to return a car, at least that's how it is for used cars.
    52,848
    wow, no idea. i have never experienced anything like this in my gen II. hard to believe gen III would be worse. maybe new tires and sound deadening?
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Huh.
    First, check tyre pressures all around. The front should be 2 psi over the back tyres. Try either lower or higher pressures. Higher will be more bumpy, but maybe not vibrations.
    Are harmonics at play here ? Try driving either slower or faster.
    Lastly, is it you or the car ? What do passengers say ?
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Did you happen to have only the rear windows rolled down a bit? That's like the worse thing on the ears.
  6. conniem
    conniem New Member
    Dayton, Ohio
    I'm hoping it's tire pressure. I've never been in any car where I've experienced this.
    I've only had the car 24 hours. No passengers. I checked the windows, And it does remind me of the noise when the rear windows are down. But it only happens on bumpy roads. Different speeds don't seem to be involved.I've only spent an hour in the car so far. I'll get the tire pressure checked tomorrow. Thanks all.
  7. bisco
    52,848
    white noise headphones?
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i get the buffing sound that resonates like a sub woofer when the back window is rolled down more than a few inches. as far as anything else. the car is much quieter than most cars i have driven before (not counting Leaf since it does not make any noise)
  9. bisco
    52,848
    yes, i get that too, but in many cars.
  10. conniem
    conniem New Member
    Dayton, Ohio
    not sure what you mean
  11. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    My daughter lives in West Chester, Ohio. She bought a 2011 III in October, and is thrilled with it. Surely the roads are equally good or bad throughout the state? Tire pressures, balance, lateral runout and possibly a damaged wheel or alignment might be causing the problem. Did you test drive the same car that you actually bought over those same roads? Time to take it back to the dealer and have the service manager or a technician ride with you. Good luck.
  12. rogerv
    1,639
    317
    If only a rear window is open, some cars set up quite a racket from the wind.
    Oops, missed your edit about the white noise earphones.
  13. sharol46
    sharol46 Junior Member
    89
    kansas
    How far do you drive on the rough, country roads? My 3 week old Prius 4 (2012) travels a half mile each way on a gravel road and driveway. I don't get much speed on the gravel,(and that is certainly a possible difference) but I haven't noticed the noise you describe. Can you get your service guy to drive with you so that he can hear what you are experiencing. Maybe there is a piece of missing insulation somewhere or a window seal that isn't (sealing). It surely shouldn't be roaring.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    the aerodynamics of the car creates a vacuum as airflow is directed around the car and the vacuum is strongest (or at least seems so) at the rear windows.
    when they are open and no other windows are open they create situation where there is air being sucked out of the car due to the vacuum but being impeded because there is no pressure relief (another open window) so you have a situation where the air is flowing out and in at the same time trying to create a balanced air pressure which is impossible due to the forward movement of the car.
    this is a very low pitched vibration=like sound like a subwoofer but with no beat that is very very annoying
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    How would a bumpy road figure in ?
  16. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    A rhythmic vacuum correction. ;D
  17. bisco
    52,848
    bose makes noise cancelling headphones by introducing 'white noise'. you can't hear it but it blocks outside souds to the brain. and, you can listen to your favorite music at the same time.
  18. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    We also notice road noise. My wife is a horse trainer in Ocala area and some of the rural roads are washboarded or just a coarse surface...so the noise transmits into the interior. Fortunately we don't need to travel very far or very fast on these few roads.
    I'm sure the application of sound deadening material in the doors (under carpets too) would help cut down.
    We traded a 4 Runner for the Prius and the 4 Runner was really quiet on those surfaces.
  19. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I thought your advice was tongue-in-cheek but in case you're serious, wearing headphones while driving is illegal here in Texas. Probably so in Ohio too.
  20. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    If you cannot overcome the noise, then get a different vehicle.
    End of story.
