"Real" reason to remove wheel trim rings
Discussion in 'Gen 2 Prius Main Forum' started by David Beale, Aug 15, 2007.
  1. prius2go
    prius2go Member
    312
    I now need back toyota wheel caps to see how that looks with the wheel trims off
    Anyone seen them on another toyota?
  2. Tideland Prius
    16,678
    <div class='quotetop'>QUOTE(Sarge @ Aug 17 2007, 06:29 AM) [snapback]497763[/snapback]</div>
    D Rock pretty much summed it up (although that's from the detailing your vehicle file lol). The entire file is in the C/M/T forum.. I've posted it up and I believe it's a Sticky.
  3. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 17 2007, 11:15 AM) [snapback]497817[/snapback]</div>
    Indeed he did! I was just expecting a yes or no answer to my question. :p Thanks also to Darwood for his suggestions, I'm gonna look for this Citrus Magic stuff...
  4. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    And the "crud" under the trim rings won't hurt your wheels.
  5. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    While washing the Prius yesterday, we removed the rings to get the crud from under them.
    So, I asked Dear Hubby if we should leave them off.
    His response? "I'm cleaning them. They d*** well are going back on!"
  6. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I took them off the evening I brought the car home from the dealership, so I can't speak from personal experience...can't imagine they'd make a difference that's actually measurable under real-world conditions.
    I remember, from school, that the wheel wells actually tend to be high pressure areas (on normal production cars without a bellypan). You can see this when driving in the rain, how the mist spews outward from around the tires.
    Wondering if taking the trim rings might, if anything, actually help aerodynamics...?
    Just a thought.
  7. dogfriend
    7,512
    1,191
    Carmichael, CA
    I had this thought a few weeks ago:
    Has anyone ever measured the road noise with / without the trim rings? I wonder if the trim rings might dampen out some of the tire noise.
    I'm not volunteering to do this measurement - I would still leave the rings off even if they cut the noise by 50% - I think the wheels look much better without them.
  8. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The 15" and 16" wheels are painted aluminum. Any dirt accumulating under the trim rings will hold salty water in the winter (where it's used and along coastal areas where it is blown). This will promote corrosion of the aluminum as any paint has micro holes through it. There are also scratches that can be deep enough to penetrate the wheel paint - scratches from the trim rings themselves even. Usually wheel paint is very tough stuff - wish they could use it on the bumper cover and hood. But it can be compromised. I've owned three vehicles with aluminum wheels now, and after 5 or more years they have all had corrosion on the aluminum wheels. And we don't use a lot of salt here or get temperatures that allow corrosion over long periods of time (it doesn't happen when it's below zero, for example).
    I'll be leaving the trim rings off. I too think the wheels look better without them.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Mine came off today because after nearly 3 years in the AZ desert, the ABS plastic became brittle enough where the clips simply broke w/ light effort to remove them. One was broken when I got to it, the second broke as I removed it when rotating my tires. The other two are still in tact, but once one has to come off, they all come off.
    I wouldn't mind replacing them, but sadly if they'll only last a few years again, there's probably not much point, as they didn't offer the protection from curb rash/road debris that I thought they would (still have a scrape on one rim). The car is a bit naked now though as I've had them on for almost 4 years now.
  10. DLC82SV
    DLC82SV Member
    241
    119
    How do the steel wheels and winter tires affect fuel economy and drivability? Also what winter tires are you using at what pressures and are they low rolling resistance tires?
