Real wheel skirts.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bestmapman, Jun 11, 2008.
  1. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Looks like Hybrideffects has got the first skirts out. They look pretty good too.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I just see the aero wheel centers for sale.
  3. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
  4. Stefx
    Stefx Member
    336
    For the wheel caps they don't specify if it's for 15 or 16 inch wheels. I sent them a query about it.
  5. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    the Hybrid Effects wheels skirts dont match the body lines at all ...yuk yuk
  6. drees
    drees Senior Member
    1,782
    247
    I think you are being overly harsh here. Because the Prius was not designed with wheel skirts, fitting aftermarket skirts are not going to seamless blend in. The rear wheels just stick out too far. It's going to be hard to make skirts blend in any better.
    I think they've a good job with them.
  7. KandyRedCoi
    860
    SoCal/AZ/NV
    all they have to do is cut a it a bit higher with a better angle IMO
  8. Flying White Dutchman
    4,376
    313
    and wil these fit with the touring 195 wheels?
  9. Stefx
    Stefx Member
    336
    I emailed them. The wheel caps are for 15" wheels only (for now) and are attached using double sided tape.
  10. darelldd
    6,059
    389
    Northern CA
    You're kidding! Double-sided tape? We'll want to remove those for cleaning/inspection. Tape ain't gonna cut it. :(
  11. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Folks,
    in the interest of clarity and fairness, it would be best to state in each
    posting which of the two rear wheel skirts are being addressed, either those
    by lyekka, or those by Hybrid Effects. Although I have been
    following the developments closely, it was not immediately clear to me that
    the sticky tape method of attachment is used by Hybrid Effects.
    On the other hand, lyekka has said:
    Details like this may make a significant difference in the fitment of the
    parts, ease of removal, and perceived suitability and quality of the offerings.
    Again, I ask that to avoid confusion and misunderstanding -- and possible hard
    feelings --posters identify the maker of the shirts being discussed in each post.
  12. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    I'm waiting for lyekka version.
  13. Stefx
    Stefx Member
    336
    Here is the response I got by email
    So if they're taped to the rings only, you could remove the ring+cap to perform your inspection?
  14. KandyRedCoi
    860
    SoCal/AZ/NV
    IMO hybrideffects piece is YUCK:)
  15. Stefx
    Stefx Member
    336
    For Hybrid effects, sticky double sided tape was for the wheel caps, not the skirts IIRC.
  16. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I think the Hybrid Effects skirts will look great. The design is almost as good as it could get for the size and price. I tried to see how well a skirt could be made on this post here http://priuschat.com/forums/prius-modifications/46100-adding-rear-wheel-skirts.html and found that my design and the Hybrid Effect design almost match. If you were to refine my design to make it actually work you would realize that in order make enough room for the tire you must push out the skirt at the bottom a few inches. You don't see that in my poster board design but it really is needed.
    With that said the only thing I could see that may make the Hybrid Effects skirt look a little better would be to give it a more bubble shape and try to lose the very very small flair at the bottom. That flair actually looks like it might be so small you might not even notice it unless the lighting is just right.
    If you want a more smooth skirt the only other option is to have a very large body kit to start at the rear door and end at the rear bumper like the Yura style seen here. http://priuschat.com/forums/prius-modifications/37756-aero-prius-yurastyle.html#post506048
    If someone can make a skirt look smooth like Yura, small like Hybrid Effects, and cheap like Hybrid Effects well then you have my money but because of the shape of the car and the way the tire sticks out there really is no other way to make a small skirt other than the way Hybrid Effects made it.
    I'll report back with my review of the Hybrid Effects skirts when I get them.
  17. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    Any progress on the skirts?
  18. Godiva
    Godiva AmeriKan Citizen
    10,339
    Anyone know if they'll fit the 2009?
  19. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I sent a PM to Lyekka on 07/27/08 asking about progress. I haven't gotten a
    response.
    I sure would like to see a second offering in the very near future... even a
    PhotoShopped graphic to show where she's going would do for a starter.
  20. n5126h
    n5126h New Member
    I would be interested in a set as well.
