Real World MPG Numbers
Discussion in 'Gen 4 Prius Fuel Economy' started by krmcg, Jan 22, 2016.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yeah, I might even reach a decade backwards to an old Texas Instruments Calculator. There's a definite "Commodore 64" look and feel to the Gen 3 dash.
    Oh well, I prefer to think of it now as the "Classic" look.
  2. Starship_Enterprius
    Starship_Enterprius Active Member
    334
    163
    Ottawa, Ontario
    2018 Prius Prime
    agree...as a G3 owner, I often find myself looking enviously at other car displays also.
  3. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    100% gas
    95% gas with 5% ethanol
    90% gas with 10% ethanol
    85% gas with 15% ethanol
    varying octane levels and combustion behavior based on other additives and your elevation and temp and such.
    The computer in the car makes an assumption on what kind of fuel you have in the tank but over time it adjusts. If the assumption is close to accurate then the MPG change will be minor. If the assumption is inaccurate the MPG change could be noticeable.
  4. The Electric Me
    9,083
    5,801
    I'll stay out of the debate of whether cars "learn"....as I think it is semantic at it's heart.
    But I think the problem is when we apply human terms to inhuman objects or machines.
    I work with machines and have fellow operators that will deal with problems (and most likely take a break) by hoping a machine problem or breakdown fixes itself magically if they let a machine "rest".
    This nearly never really works. I usually make no friends at work when I explain it's a machine, and therefore doesn't really benefit from a random rest period. And that the "let it sit" period usually just becomes time wasted that could be used in actually fixing the problem.
    Computer controlled systems make the definition a little more difficult. Computers can adjust parameters given different input, but is that "learning"? Well, by my definition real learning requires self awareness. The Prius is advanced....but the continual reverse beep tells me, it's NOT that advanced.
  5. bisco
    52,854
    so, iow, it can't learn from the first half of the tank to the second half?
  6. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    One thing I like better about the gen 3. vs. gen 4. Instrument panel is the engergy flow monitor.
    1. It seems to be quite a bit larger.
    2. I prefer the arrows apearing and disappearing over the new look .
    I will get used to it I guess,and its great it has color now,but I do like the moving arrows more .
  7. krmcg
    2,592
    2,393
    Whittier, CA
    I noticed that the full battery does not turn Green like it did in the Gen 2
  8. dhanson865
    851
    188
    TN, USA
    what gave you that idea?
    It learns on the fly every time you run the car. It does average the results over a longer period but it is a moving average and will definitely change from one half of the tank to the next if you have a change in fuel from the prior fillup(s).
    Every manufacturer uses logic they don't share with end users so I can't tell you how many off/on cycles vs time vs miles it would take to fully adjust but I don't understand why you believe it doesn't.
  9. bisco
    52,854
    even on the first tank ever?
  10. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    That's less than the cost of a 16 oz bottle water at that convenience store! :D
  11. ETC(SS)
    7,554
    I don't waste that either.... :)
  12. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Water has always been more expensive than fuel at a station. Worst still at a "convenience store".
    tucatz likes this.
  13. dhanson865
    851
    188
    TN, USA
    Even on the first tank, if the first tank of fuel is different than the mapping in the firmware the engine computer will adjust over time to the actual fuel vs the expected fuel.
    The only way it wouldn't adjust is if somehow the fuel mapping was 100% correct for the actual fuel in the car on the first try. Since it was shipped from the factory to the dealer with an empty or near empty tank and then filled up by the dealer the first tank will vary from dealer to dealer.
  14. bisco
    52,854
    thank you.
  15. Trollbait
    12,827
    If I had to guess, I'd say the default fuel for the ECU's assumption is whatever the legally required blend is for emission and fuel economy testing. For the EPA, it an alcohol free blend of 93 octane, or 91 for California testing.
  16. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    Here's my MPGS today coming into the office. 62-65mph freeway. 54*F, early, light traffic, a few uphills at the end of the drive. Still looking for the "sweet spot" on coasting.
    kammssss, bisco and krmcg like this.
  17. krmcg
    2,592
    2,393
    Whittier, CA
    Very Nice!
  18. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    KRMCG -- Your numbers are amazing. I have a challenge! My numbers (mostly on the highway) are above.
    Here are some data from the east coast:
    Fill up at 500 miles
    9.3 Gallons (Second click)
    53.8 MPG calculate
    54.4 MPG on Display
    105 Miles to Empty on Display
    #58 ATHiker, Jan 28, 2016
  19. bisco
    52,854
    it's a bit colder here.:p
  20. AKCoffee
    AKCoffee Junior Member
    46
    23
    2014 Prius v wagon
    I'm impressed by both the drivers and their 4G's. A bit jelous, too.
    kitkit201, krmcg and bisco like this.
