Realistic battery life
Discussion in 'Gen 3 Prius Technical Discussion' started by Andres V, Sep 27, 2018.
  1. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    No where I've read you have to replace the ECU when you just replace the batteries.
    I personally would rather keep my rather than replace the whole unit. Since it's been with the car,
    seems there would be less chance for a problem, it one might happen.
    amos and Mendel Leisk like this.
  2. amos
    amos Active Member
    376
    285
    los angeles
    Got the code P0A80 again (3rd time). this time went to the dealer with code displayed. Its saturday now .was told they must get toyota aproval to replace HV battery. Was here last week too , code didnt show but was recorded twice at the computer code scan history. Dealers policy is :no code no problem so had to wait for code to show.
    Seems like warrenty will cover. Car is 2013/120k.
    Also, dealer said will not replace the ECU cause no need but lets see if this changes.
    Dealer said will provide a free rental only after toyota approval which is monday.
    With all that 3 times code showed, i noticed the triger for this code was when battery was fully charged so i didnt have any problem of duplicating it again. Just need to drive the car at a steep downgrade road , push the brake and voila battery full and code P0A80 and all other lights on dash like check engine etc... ,are displayed
    #82 amos, Dec 29, 2018
  3. HBS
    HBS Member
    74
    56
    MO
    Here is a good one which confirms my personal opinion regarding the first gen 2 batteries; they are oldies but goodies.
    Owner: Professor
    Car Mfg Date: 08/03 (15+ years)
    Mileage: 300k (cluster stopped at 299k)
    Car Condition: Below Average but good maintenance.
    Problem: block 3, failed module.
    Raytheeagle and amos like this.
  4. HBS
    HBS Member
    74
    56
    MO
  5. amos
    amos Active Member
    376
    285
    los angeles
    dont have a techstrwam sorry.
    Update
    Got the car back from dealer. New HV battery new serial# and warranty. ECU not replaced but update performed J0V00B op code. All under warranty. No charge.
    So for the statistics sake : battery lasted 120k miles
    Raytheeagle likes this.
  6. Mendel Leisk
    42,386
    Congratulations, high-fives!
    Maybe @Andres V can use your experience in his battle to get battery replacement without ECU needing to be replaced? Post a picture of your invoice with personal info redacted?
    Robert Shields and amos like this.
  7. Leadfoot J. McCoalroller
    8,295
    7,814
    Pennsylvania
    2018 Prius c
    ...the other end of it, the calendar? A 2013 might have been built spring 2012, so call it 81 months?
  8. amos
    amos Active Member
    376
    285
    los angeles
    Update
    @Mendel Leisk . First time i went there with no code shown on dash and no CEL .and though the reading showed that code popped twice , dealer said very clearly come back when code is showing or else warranty won't cover. @Andres V
    #88 amos, Jan 7, 2019
  9. HBS
    HBS Member
    74
    56
    MO
    Here are a couple more:
    2005 13 years 5 months from battery mfg date. 251k miles.
    2007 11 years 5 months from battery mfg date. 260k miles.
    Raytheeagle and Robert Holt like this.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Great life on them. You been maintaining them with that charger? (y)
  11. HBS
    HBS Member
    74
    56
    MO
    No just reconditioning them.
