Really dumb question about TsS
Discussion in 'Gen 4 Prius Main Forum' started by Frederickdawg, May 18, 2016.
  1. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    My tests are inconclusive at best. It does not detect pedestrians or give you warnings while parking/ Maybe/sometimes/every odd Sunday.
    It may assist cross traffic/not sure?????? It may feeds the lights in the rear view mirrors. Still a mystery to me.
    #21 ETP, Jul 17, 2016
    Tideland Prius likes this.
  2. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    It definitely warns during parking, that's the whole point, and is important for the parking assist (if equipped). It's also used for blind spot monitoring, but I think that's a much simpler algorithm/function.
    Rear cross traffic alert uses two additional side-facing millimeter wave radars according to diagrams and descriptions I've seen. The sonar sensors aren't sufficient for that function; RCTA picks up traffic at a greater range than the sonar supports.
    ETP likes this.
  3. ETP
    2,804
    1,170
    Auburdale FL
    Thanks, great info.
    It may during assisted parking mode but I do not see those warning sensors pop on when I enter my garage. Only the other 8 light up.
    Due you also have PCP?
    Also too many terms to keep straight. I remember the lights on the mirrors and that is that.:ROFLMAO:
    #23 ETP, Jul 17, 2016
  4. wrprice
    415
    308
    Houston, TX
    Four Touring
    I have a Four Touring with PCP, so all of the ATP minus the HUD and moonroof. My side sensors do trigger when I pull into my garage. We park two cars and I need to leave enough gap in the middle of the garage to manage a small child and car seat. I pull in with my right side mirror about an inch or two from the edge of the garage overhead door frame. It usually triggers then, but if it doesn't then it certainly does when I vector slightly right once the mirror is clear.
    I believe the warning distance is shorter for the side sensors, compared to the front/rear. That makes sense when you think about narrow parking spaces where you'd expect there to be other cars relatively close to the sides. I imagine they walked a fine line tuning those sensors to find a balance between annoyance alerts in tight spots and warning distance for problem obstacles.
    I've never had the car automatically apply the brakes because of a sensor during parking.
    #24 wrprice, Jul 17, 2016
    ETP likes this.
  5. ETP
    2,804
    1,170
    Auburdale FL
    You are right and I am wrong!!!!!!!!!!!!!!!!!! Pics enclosed!
  6. wrprice
    415
    308
    Houston, TX
    Four Touring
    The other limitation, because of the sensor recording magic, is that an obstacle has to pass through the range of one of the side sensors before it will register. If you stop right next to a pole, right at the B-pillar and wait (or park, shut the car off, and start it later) it won't remember that the pole is there even though it could be inches from your paint. The same applies if something were to be placed there later, or if something like a gate were swinging/approaching dead on from the side.
    In the warning screen, you may notice that the sides of the car have no sensor areas depicted (all black) until the car moves enough distance for it to know that area is clear (or not). As you back out of a space slowly, after starting the car from off, you may notice the two zones on each side (front/rear door areas) will change from black (no data) to solid gray (no obstacle).
    ETP likes this.
  7. ETP
    2,804
    1,170
    Auburdale FL
    Keep teaching me folks. I forget after 10 minutes.
    OK, still need to be able to sense the walls at a proper distance with the speed brakes out.
    #27 ETP, Jul 17, 2016
  8. ETP
    2,804
    1,170
    Auburdale FL
    So is the range detection adjustable for the side sensors? At present they have no use for me as it would maybe scrape the mirrors before a warning would go off.
    dfine1966 likes this.
  9. wrprice
    415
    308
    Houston, TX
    Four Touring
    There's a sensitivity adjustment somewhere, either in the settings screen or Carista. I don't remember which. However, I've not seen anything that adjusts the side sensors separate from the front/rear.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    ***Be aware that if you chicken out and touch the brake (or gas pedal) when the brake assist warning sounds or when DCC is on and you're approaching the car in front, the car does not automatically brake***
    ETP likes this.
  11. ETP
    2,804
    1,170
    Auburdale FL
    I be a big chicken. Foghorn type.
    kithmo likes this.
  12. wrprice
    415
    308
    Houston, TX
    Four Touring
    Good advice. If the systems detect sufficient input from the driver, they interpret it as you saying "I've got it!".
    ETP likes this.
  13. ETP
    2,804
    1,170
    Auburdale FL
    TsS = Technical Stupidity syndrome. = Me.
    kithmo likes this.
