Rear 12v outlet
Discussion in 'Prius v Technical Discussion' started by jonb505, Nov 23, 2012.
  1. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Anyone use the rear 12v power outlet?
    I've been racking my brain trying to figure out a use for the 12v outlet located in the cargo area.
    Only thing I came up with is you could plug in a power inverter so you can charge your laptop or other device in the cargo area while traveling?
    Maybe its a carryover from the JDM 7 seater model where it provided a power outlet for the 3rd row passengers.
    Perhaps this is a common feature on most crossover/suv types but this is my first car that is not a subcompact where i've only ever seen one 12v outlet in the front. Am I missing an obvious reason why they put a 12v outlet in the trunk? :confused:
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,003
    6,894
    Texas Hill Country
    I suppose you could put one of those portable jump starters back there, eg one that float charges off of the 12v. Another possibility might be a 12v portable refrigerator while traveling.
  3. Adam Leibovitch
    498
    102
    To plug in emergency devices while pulled over on the side of the road
    Bmr4life likes this.
  4. fuzzy1
    10,687
    And to plug in 12V appliances (lanterns, pumps for air mattresses or inflatable boats, ham radios on Field Day, telescope equatorial drives during star parties, etc.) while car camping.
  5. n0na
    n0na Junior Member
    88
    WA
    The 12v socket is switched, so it provides no voltage when the car is shut off. (At least that's what I understand; I've never tested it.) That's a disadvantage for some uses. But, it allows you to control a relay from that 12v socket and the relay can then supply high current directly from the 12v battery for equipment like a ham radio that requires relatively high current with minimal voltage drop from the battery. When the car is shut off, the relay opens and you won't have to worry about running the 12v battery down. You can't connect the ham radio directly to the 12v socket because it may draw more than 10 amps that the socket is fused for and, even worse, the long small gauge wire between the socket and the battery would have too much voltage drop for the ham radio to operate properly.
    Tom_consulting likes this.
  6. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Yeah the camping idea makes sense. As nOna says it likely does not provide power with the car off but if you back into your campsite it is a convenient location to run a mattress pump or light from. With the limited current draw available on the outlet I would assume you could have the car on for quite awhile without having the engine fire up to charge the battery. More convenient than stringing cables from the front cabin 12v outlet.
    Another thought is having your smartphone charge cable plugged in there and just string the cable out so the rear seat passengers can reach it. I believe most phone chargers have long enough cables for that.
    I'm sure in my years of v ownership i'll eventually end up using it for something.
    I do actually have a small lithium ion emergency booster pack i picked up a while back when i had battery problems on my old car. I think it does have a 12v charging cable. When my roadside assistance warranty runs out maybe I'll keep that in the back.
  7. butchbs1985
    butchbs1985 Taking things apart is fun!
    245
    23
    ChicagoLand
    2013 Prius v wagon
    Old thread but.... Has anyone looked into changing this so it isn't dead when the car is off. It would be sweet to put one of the coolers with the 12V connector in the back for road trips / camping so I wouldn't have to deal with the ice. Yes I of course understand that the cooler shouldn't be left running in there all night but when you stop for lunch / sightseeing, it would be cool to leave it running.
    Also,
    Are all of the power points on the same fuse? The manual reads that way. Bummer if they are but I guess it's nothing that a pair of snips and a spare fuse slot can't fix.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You will need a lot more 12 volt batteries if you have it always on, the stock Prius battery is very small.
    My best advice is to never use electrical power when you are not in Ready.
  9. butchbs1985
    245
    23
    ChicagoLand
    2013 Prius v wagon
    Yep. I'm just talking about using it when a stop is made for food / activity. Just an hour or so. Nowhere near enough power draw to drain the 12V battery. I certainly would never suggest someone do it overnight.
  10. fuzzy1
    10,687
    Please re-think that, as even the 'or so' puts the small Prius 12V battery at risk. I suspect these coolers are a major reason that automotive 12v outlets are now switched off.
  11. butchbs1985
    245
    23
    ChicagoLand
    2013 Prius v wagon
    Fair enough though I would disagree that there is any major risk of damage. The battery is 32 Ah and a cooler only draws about 4. That said, I could safely run the cooler with the car off for 8 hours before full depletion (assuming full charge and properly operating). One or two hours wouldn't even come close to endangering the battery.
    As for being switched off due to things like that, you're likely right. Seeing that I have to explain the Ethernet cable on our customers PC's as 'the giant phone plug', the general public is likely not intelligent enough to realize the limitations of the vehicles and would even draw down the huge 12V battery that's in my Ram.
  12. fuzzy1
    10,687
    Don't forget a few more complications:
    * The 32Ah capacity is for a new battery. It shrinks considerably with age;
    * Prius seems to recharge the 12V battery remarkably slowly;
    * My Prii seem to run at a significantly lower typical charge levels than the previous nonhybrids, considerably short of fully charged. This didn't bother my first Prius at all, which started quite happily at a voltage where my non-hybrid couldn't crank.
    Put all these together, and I suspect that at many typical moments, the battery has far less available charge than you may expect. Stretch that one hour to two hours, multiple times (when the Significant Other takes 'just an hour', how long does it really take?), and suddenly the battery may be experiencing repeated deep discharges. Common automotive batteries don't last long under under this use.
  13. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    I don't have any experience with these electric coolers, sound like a great idea though, and perfect use for the rear 12v socket.
    But aren't they insulated well enough, like a normal cooler that turning it off for an hour or so would still keep things cool inside, or are these electric coolers insulated less than a regular ice box?
    I've used cheap coleman coolers(non plug in) from wal-mart and sitting overnight with ice in them in the summer, the ice will melt but stuff still stays pretty cold inside.
  14. butchbs1985
    245
    23
    ChicagoLand
    2013 Prius v wagon
    Yes they are in fact insulated but take a while to cool off so any loss isn't ideal. Depending on which one you have / get, some work great and others are just so/so.
    Basically, I like my beer cold while camping and enjoy tinkering with electronics / everything that I can change. I've never much liked not being able to do something :)
    That's just the first thing that I thought of when I saw the power point there. Once my kid is older I'm sure it will be driving a power inverter and such while we're moving as well.
  15. xPETEx
    xPETEx Junior Member
    76
    Victoria, BC, Canada
    2013 Prius v wagon
    I love the fact that it turns off with our cooler plugged in. I've drained car batteries in the past with the cooler, and have no desire to drain the one in the Prius. It will stay nice and cold when you stop for lunch. If you're really worried just leave the car in ready mode and lock it (i.e. put the window down, close the door, lock the doors, and hit the automatic window up button).
  16. butchbs1985
    245
    23
    ChicagoLand
    2013 Prius v wagon
    I like you're style! Never thought of doing that but wished I could do such a thing a few times in my old Prius!
  17. Woody111
    Woody111 Junior Member
    NE Florida
    It's a great for people in the back seat to plug in chargers for iphones, ipads, DVD players, etc. on road trips. Especially for kids. I already have the front outlets occupied and it reduces the cords going from the front to back seats. You may want to add an extension cord and splitter.
    FriarNurgle likes this.
