Rear ABS sensor fault after replacing wheel hub assembly
Discussion in 'Gen 3 Prius Technical Discussion' started by tonymats, Feb 27, 2026.
  1. tonymats
    tonymats Junior Member
    New York NY
    Thank you, everyone! It ended up being a torn wire under the insulation. Quick soldering job fixed it right away, no parts required.
    rjparker and Brian1954 like this.
  2. ChapmanF
    18,997
  3. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Glad you found it. Did you find HOW it got damaged?
    Where in the harness was it? By the connector?
