Rear amber turn signal bulbs -- brightness question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by alexpm, Aug 23, 2006.
  1. alexpm
    alexpm New Member
    I have just purchased a new 2006 Prius, Package #6 and find that the rear amber turn signals are comparatively dim, especially during daylight. I would like to know if the bulbs used for those signals can be switched to a brighter bulb without, of course, compromising the electrical system in any way. A service technician at Marin Toyota in San Rafael, CA could only give me the Toyota part number of the standard turn-signal bulbs, but said that they "look like" commercially-available #7443 amber wedge-type bulbs, 21W-12V except they only have one filament. Does anyone have experience or an educated opinion about a turn-signal upgrade? An aftermarket LED substitute would be awesome, but I'm not going to get too obsessed here... Many thanks.
  2. glenk
    glenk Member
    109
    Fairfield, CA
    I'd have to agree with Primo. The turn signal intensity is weak on the prius. I was directly behind one on my bike and I had a hard time seeing it blink. An intensity upgrade would be a good idea.
  3. nyconrad
    nyconrad Cconrad in Virginia
    222
    Powhatan, Va
    I also just noticed this yesterday as my wife was pulling out of the driveway. I was barely noticable, especially when the brake light went on. I too would be interested.
  4. brandon
    brandon Member
    771
    Manhattan, KS
    eh, just replace them with yellow high-intensity strobe lights. :D
  5. Jack Straw
    Jack Straw New Member
    137
  6. GreenSpeed
    GreenSpeed New Member
    201
    <div class='quotetop'>QUOTE(brandon @ Aug 23 2006, 03:04 PM) [snapback]308484[/snapback]</div>
    Eh? Strobe lights? You're pulling our legs right? Check out VFaq it might be helpful to you.
  7. brandon
    brandon Member
    771
    Manhattan, KS
    <div class='quotetop'>QUOTE(Green Speed @ Aug 23 2006, 06:15 PM) [snapback]308523[/snapback]</div>
    Ha! Mere child's play. Just pop some of these babies into the sockets; that'll solve the problem. Just modify the existing socket and assembly, make a slight change to the hybrid power system so that it puts out ten times as much juice, and you'll be good to go! :lol:
    ... and yes, I'm pulling your leg! :D
  8. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(brandon @ Aug 23 2006, 09:19 PM) [snapback]308584[/snapback]</div>
    LOL too funny, I would check the local laws for strobe light usage, just for giggles....
    I did mount a dual head amber LED light on the top left rear corner of the rear window as a Hazard light for those times when changing a tire or something as the rear hazard lights are dim... I too would like to know of a replacement bulb..
    The light has two light heads combined similer to whats pictured below but in yellow..
    http://www.oznium.com/images/whelen_talon_1.jpg
    http://www.oznium.com/images/whelen_talon_2.jpg
    It only faces to the rear and is only used in an emergency..
    Plus it only pulls 0.05 of an amp...! ;)
  9. hycamguy07
    2,707
    Central Florida
    Hmmm, the topic died.. :huh:
    Anyone find out anything on a brighter sollution?
  10. naterprius
    naterprius Senior Member
    1,843
    Take the link for Vfaq. Answers are there.
    Nate
  11. talonts
    talonts VFAQman
    448
    69
    <div class='quotetop'>QUOTE(priusguy04 @ Sep 7 2006, 11:24 AM) [snapback]315763[/snapback]</div>
    http://vfaq.net/mods/Lights.html
    Search the site linked (note - they are constantly breaking my links to the bulbs, so just go to http://www.optionsauto.com/ and search for the part #s I have listed, then search for similar bulbs if you want amber) there if you want brighter amber bulbs. I hate amber rear turns, so used red as noted in my VFAQ.
  12. hycamguy07
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(talonts @ Sep 8 2006, 05:29 PM) [snapback]316609[/snapback]</div>
    I still cant find the Super Bright Yellow bulbs. I want to stay with the OEM look, becides all studies show yellow is brighter than red in all road conditions... ;)
  13. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    <div class='quotetop'>QUOTE(priusguy04 @ Sep 8 2006, 07:31 PM) [snapback]316769[/snapback]</div>
    Yes, and yellow is also very obvious for a turn signal. It won't be mistaken for a brake light and vice versa.
