Rear axle beam assembly repair
Discussion in 'Gen 3 Prius Main Forum' started by John Lloyd, Nov 28, 2023.
  1. John Lloyd
    John Lloyd Junior Member
    Amherst, MA
    I've got a 2010 Prius with 135,000 miles on it that's been running great. I bought it new and it's been well maintained. The other day the wheel broke while parking it. Looking at manual diagrams, it looks like a lower control arm broke. My service garage told me the car would need a new rear beam assembly, and it wasn't practical to repair. I can't find any Toyota recall for the problem, or class action suit on it. Should I bring it somewhere else to have it looked at, or am I basically SOL.
  2. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    I'd rake it elsewhere, and if something on the frame is broken a body shop may be able to weld it.
    John Lloyd likes this.
  3. Leadfoot J. McCoalroller
    8,288
    7,800
    Pennsylvania
    2018 Prius c
    That doesn't usually happen without advanced corrosion. How rusty is this car?
  4. bdc101
    bdc101 Member
    250
    usa
    Agreed - if it's rusted out it's probably time to replace the beam axle, and possibly more than that. Did your mechanic not tell you WHY it broke? These things don't tend to break except by excessive rust.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,085
    6,947
    Texas Hill Country
    Junk yard
  6. John Lloyd
    Amherst, MA
    The outside body is essentially rust free (just waxed it), but there's considerable rust underneath. But I didn't think it was so bad the wheel would break. I'll upload a photo. IMG_1713.jpeg
  7. John Lloyd
    Amherst, MA
    Rusty, but I didn't think so much that it would cause this failure.
    Yeah, he said it was rust, but thought it shouldn't have failed like that, and suggested I try to work with the Toyota dealer for some kind of compensation or repair.
    #7 John Lloyd, Nov 29, 2023
  8. John Lloyd
    Amherst, MA
    One other note - the garage replaced a wheel bearing on the same wheel three weeks earlier. Could that be related?
  9. rjparker
    11,085
    6,947
    Texas Hill Country
    Could be. An oem wheel hub would never fail like that but they cost $250-$400 for the part alone. Cheap ones fail quickly. Take a pic with the tire off and some light on the subject.
  10. John Lloyd
    Amherst, MA
    Replacing the wheel bearing cost me $675 - wheel bearing assembly $355, wheel speed harness $70, and labor $250. I'll try and get some pictures when I get a chance.
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    The only repair is to replace the axle beam assembly which is apparently rusted through.
    Rust does not start on the painted surface of the car's body. It always starts underneath.
    This might be a lesson for those who do not believe in rustproofing.
  12. bdc101
    bdc101 Member
    250
    usa
    Crazy to think that a mechanic could do all that work and yet not recognize it was structurally about to fail catastrophically. Says something about the mechanic.
    Usually the rust-perforation warranty is much longer than the rest of the vehicle, but at 13 years of age it might not still apply. Regardless would be good to bring up with Toyota.
    Daniel L McMillan and John Lloyd like this.
  13. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    If the axle beam is in such bad shape with rust, the rest of the undercar components are likely in bad shape, too.
    It might be time for a new car.
  14. Mendel Leisk
    42,341
    Toyota should hot-dip galvanize the suspension. I looked at ours after a few years, though what the heck is happening, started cleaning and coating everything I could reach, with boiled linseed oil. That's worked out good, but Toyota's rust protection is zero...
  15. John Lloyd
    Amherst, MA
    The mechanics are very good. I've used them for almost 30 years. They did say they plan to visit this issue, mentioning how some of the old Tacoma's were poked with a screwdriver and declared undriveable.
    I did speak with my Toyota dealer, where I purchased it new. They couldn't offer any help. They mentioned for 'loyal' customers, ie. had all my servicing done at their dealership, that they might go out of their way to make it right.
  16. John Lloyd
    Amherst, MA
    I've always (except when I was young and poor) bought cars new and driven them into the ground - about 15 years. I've never had a catastrophic failure like this. I've had a couple frame welds, on my '89 Toyota pickup and an old diesel VW rabbit. I always thought the dealer rustproofing was a ripoff, plus newer cars are so much more rust resistant. I need to look into what's being offered for rust proofing these days.
  17. John Lloyd
    Amherst, MA
    yeah, I got a new car almost two years ago. I've been sharing the Prius with my son, and planning to give it to his sister. :-(
  18. Leadfoot J. McCoalroller
    8,288
    7,800
    Pennsylvania
    2018 Prius c
    Could be a trick of the light, but the photo seems to show a lot of wear on the inside edge of the tire tread, suggesting that there's been a problem for a while now.
  19. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    You are correct. They did a shoddy job and sold the warranty.
    The military does a good job on their vehicles. Correctly done, rustproofing is very labor intensive and very effective.
    One that has a good reputation is New Hampshire Oil Undercoating.
    Home - NH Oil Undercoating
  20. John Lloyd
    Amherst, MA
    Interesting. I'll have to take a closer look at the tire.
