rear axle beam
Discussion in 'Gen 2 Prius Main Forum' started by Buddd, Sep 7, 2017.
  1. Buddd
    Buddd New Member
    Hi. I just had my rear axle beam and linkages replaced after road hazard damage. The rear wheels are, now, way out of alignment. See att'd. photo of alignment measurements. Alignment shop owner feared subframe damage; sent me to a body shop. Owner there said that the frame's fine, but that the axle beam is shifted to the right by about two inches. See att'd. photo, shot almost head-on from the rear. He's said that the midpoint of the beam, #2, should be in line with the structure that I've labeled #1.
    Thoughts? Thanks!
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Rubber part that’s marked with 2 in your pictures is just resting in the axle beam so it can be pushed from side to side. So you can’t use it as a measuring point.
    If the mounting points on a car where axle mounts move even 1cm or half an inch it should be easy to tell just by looking at them. Also you can pretty easily measure if they have moved. Could you send a picture of those mounting points? There’s a plastic part covering those but it should already been removed to replace the axle.
    If those (two) mounting points are ok it has to be the problem in the axle new axle beam.
    And in any case the amount (and way) that camper is off can’t really even be caused by the bending of the axle beam mounting points so the new axle has to be bad anyway.
  3. Mendel Leisk
    42,171
    Was it a salvage rear beam? Maybe it was in an accident too??
  4. P Ma
    P Ma Junior Member
    23
    Yes, it's a salvaged part. I can't get a photo of its attachment points just now; they look OK. Notice on the axle beam the concave area that I've circled in yellow on the att'd. photo whereas on the right side, there's a convexity.
  5. valde3
    2,002
    750
    Finland
    So you just have a bad axle beam. Replace it with good one and then check the alignment.
