Rear axle rust and worn bushing
Discussion in 'Gen 2 Prius Main Forum' started by picassopigeon, Jun 11, 2022.
  1. picassopigeon
    picassopigeon Junior Member
    49
    Plymouth, UK
    Is the bushing in the 1st photo rusting through?
    Can it be replaced or do you think the mounting is too far gone? IMG_11-06-2022_10-57-57_8.2.204.jpeg IMG_11-06-2022_10-52-02_8.2.204.jpeg
  2. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    Gotta scrub it all clean before you can decide how bad it is or not... Can't tell you much with so much debris on everything...
    picassopigeon likes this.
  3. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Clean flaking rust off to get a better idea. Find a hand held sandblaster, probably Amazon.co.uk and clean off the flaking rust. Similar to attached pics. My calipers were similar with flaking rust, used my hand blaster and cleaned up quite nicely, exactly how they remanufacture caliper brackets.
    You'll be surprised how that little blaster blows off the rust, don't need a large compressor. Give it short bursts, don't need to hold the trigger continuously. Best $25 I've ever spent, also make sure to hold it upright.
    #3 alftoy, Jun 11, 2022
  4. PriusCamper
    13,452
    5,430
    Hopefully you're protecting your lungs if you're really using sand and not some other abrasive that safer to use.
  5. alftoy
    1,132
    519
    Using crushed glass, quite sure Harbor Freight, Tractor Supply or Princess Auto in Canada not selling blasting sand anymore.
    This is the blast media I use Green Grit crushed glass. Quite surprised to pay $15 in Canada for 50lb glass grit, Tractor Supply and Harbor Fright both over $50 for 50lb.
    50 lb Greengrit Crushed Glass Blasting Abrasive (princessauto.com)
    You only need to look at my old rotors to see the type of rust on my caliper brackets. Next to my blaster.
    $21 at Harbor Freight for the blaster.
    21 Oz. Hopper Gravity Feed Spot Blaster Gun (harborfreight.com)
    #5 alftoy, Jun 11, 2022
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Sand or glass, it's still silica- I hope that you're using a good respirator (not just a dust mask). Silica dust can do massive long term damage to your lungs.
  7. alftoy
    1,132
    519
    One that interests us greatly is the difference between Crystalline Silica (also known as “free silica”) and Amorphous Silica. Unfortunately, over time people have confused crystalline silica with amorphous silica, however, one is dangerous and the other is not.
    Glass Dust - A Quick Guide (krysteline.com)
  8. PriusCamper
    13,452
    5,430
    It's always a good idea to do a quick fact check of claims like this before you hit "post reply." specifically:
    "Sand blasting is much more dangerous to workers than typical glass bead blasting. The after-product of sand blasting is called silica dust and can cause silicosis in workers after prolonged inhalation. Because of this, sand blasting is heavily regulated. Conversely, glass bead blasting is much safer because the beads do not produce a silica dust and are lead free." https://homesteady.com/12444388/glass-beads-vs-sand-blasting
