Rear Brake binding.
Discussion in 'Generation 1 Prius Discussion' started by Ash Bennett, Apr 25, 2016.
  1. Ash Bennett
    Ash Bennett New Member
    England
    2001 Prius
    I
    One of the rear brake calipers on my 2001 is binding and it doesn't matter what I do it makes no difference. I took it for its yearly MOT (safety check) and it was the only thing it failed on. I have split the caliper, cleaned the pins, made sure everything slides as it should. When I put it all back together the hub spins easily but as soon as I apply the brake it binds again. I'm assuming now it is the caliper piston so tomorrow I will push the piston in a few times to see if it frees up. I really want to avoid changing the piston if at all possible.
    I welcome any and all ideas.
  2. Mendel Leisk
    42,079
    Does the piston have a cross pattern on it's face? And is there a pin on the back of the pads? The pin likely needs to fall between the piston spokes, to lock the piston from turning when the parking brake is applied. Even positioning it correctly can be problematic, if the pistons are not well seated before application of parking brake.
    do not know if this is your issue, but it will cause terrific drag if it is. So:
    1. Position piston correctly, to have it's spoke pattern straddle the pad pin.
    2. Reassemble.
    3. Pump the brake pedal multiple times, get the whole thing well seated.
    4. Reconnect 12 volt battery. (assuming this was done at the outset, should be)
    5. Do a short/easy test drive.
    6. Apply parking brake when done.
    Ash Bennett likes this.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    I've never seen an 01 with rear calipers. The Gen I's have drums on the rear.
  4. Ash Bennett
    England
    2001 Prius
    I
    No, the 2001 has discs with the parking brake inside the dish of the disc, almost like a drum brake but it definitely has discs
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Ok, must be a European thing cause all North American models came with drum brakes.
  6. Ash Bennett
    England
    2001 Prius
    I
    No the piston is plain and no pin on the pad itself, the piston just pushes against the rear of the pad face. The parking brake is separate and sits inside the disc dish if that makes sense.
  7. Ash Bennett
    England
    2001 Prius
    I
    How strange, I wonder why they would change something like that ?
  8. Mendel Leisk
    42,079
    Yup. That's a simpler design. And per above, even second gen North American are simple drum brakes. Third gen with rear discs are a flakey, integrated parking brake, no built-in mini-drum brake. When it works it's fine, but assembly is tricky, so not a good design in that regard.
    Sorry, not helping with your issue.
    #8 Mendel Leisk, Apr 25, 2016
    usnavystgc likes this.
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Here's what we have
  10. Ash Bennett
    England
    2001 Prius
    I
    No its not really
  11. Patrick Wong
    18,210
    6,515
    1. Any warning lights on?
    2. If your attempts to depress the caliper piston do not result in a positive change, then is it possible to swap the rear caliper assemblies to see if the problem follows the caliper? If it does, then just replace the entire caliper.
    3. If the problem does not follow the caliper then you may have a problem with the brake actuator that provides hydraulic fluid to the brake calipers.
    4. The European Classic and 2G Prius both have rear disc brakes (compared to North American and JDM Prius that have rear drum brakes.)
