Rear Brake Drum 'Sticking'
Discussion in 'Gen 2 Prius Technical Discussion' started by Robert John, Jul 19, 2025.
  1. Robert John
    Robert John Junior Member
    64
    Montreal, QC
    After a few days of wet weather & very high humidity I got in my Gen 2, and one of the back brakes 'held' for a second before breaking-free as I backed-up. The emergency brake had NOT been set. The new shoes, drums & hardware have only a few thousand kms. I did a 'roll test' on a slight slope: car rolled easily. I tried a few 'panic stops' on sand & gravel: ABS performed flawlessly, no tire locked & skidded. Once out on the road, I stopped a few times to see if either of the rear brake drums were heating-up from a 'dragging' shoe: both were cool.
    Q: Before I jack up the back and remove the tires & drums to have a look-see, has anyone experienced something similar? If so, what was the cause and/or outcome?
    Thanks!
  2. Brian1954
    Brian1954 Senior Member
    2,666
    1,066
    South Central PA, USA
    What you described is normal. It is caused by rust.
  3. Robert John
    64
    Montreal, QC
    That makes sense, but: a) In over four years, it's never happened before; and b) If it's rust, which steel part is sticking to what part of the drum?
    Thanks!
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    IF that's what happened, then rust formed on the "swept" surface of the drum. It can bond to the brake shoe friction material.
    This usually occurs when the parking brake has been applied then the car sits for weeks - months - years in high humidity.
    Personally haven't seen it on any modern drum brake vehicle that gets any regular use. Have you checked the parking brake cables for free movement on apply and release?
  5. Robert John
    64
    Montreal, QC
    E-brake cables are fine, I live in a mountainous area, so I set/release the emergency brake regularly, (although I MUCH prefer hand brakes... WAY more useful & flexible under various conditions ;-) The problem hasn't happened since, so I won't explore any further until it happens again.
