Rear brake noise after replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LuvLispy, Apr 16, 2024.
  1. LuvLispy
    LuvLispy Junior Member
    Jonesboro, AR
    Well, my rear brakes on my 2010 make the weird noise when reversing. If I depress the brakes while reversing, it will make a rather loud "click". The brakes don't make noise if I am braking when going forward.
    The rear rotors are solid Brembos, and pads are Akebono street performance ceramics. They were put on last Friday, by a rather reliable mechanic. I watched the guy put on the brakes and everything seemed okay afterwards. My car stops okay and I don't really feel anything weird.
    I read it online, some sources say it's the brake pads "shifting" when going backward? These sources claim that it's no big deal, and you just have to accept the noise.
    52,861
    if i paid some one to do it, i would ask them
  3. ChapmanF
    19,027
    Might be worth a quick look to see if the "fitting kit" was installed correctly. That's the springy little clips that go in the caliper brackets, and the "ears" of the brake pads go in them.
    The "fitting kit" comes with four of those clips, two per side of the car. They are not all identical; two of them have longer bottom "lips" than the other two. You have to look a little carefully to spot the difference.
    On each side of the car, the longer-lipped ones go in the lower groove of the bracket, so as to keep the pads pushed toward the upper groove. That's the way the pads want to move when driving forward, so there should never be a click then.
    There may be a bit of a click when reversing (though nothing that ever annoyed me). But I don't know if you might get a more-annoying click if, say, somebody put both long clips on one side of the car and both short ones on the other, or something like that.
  4. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    I just replaced all my brake pads and rotors all around and zero noise.
    My rear pads also did not have the triangle spring things to hold them down I guess.
