rear brake replacement job guide needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SamEgel, Jan 24, 2015.
  1. SamEgel
    SamEgel Junior Member
    Pompano Beach, Florida
    Hi guys, my 2008 Prius needs rear brake hardware, drum an shoes replacement. Here is what the dealer reported:
    GRINDING AND CLICKING NOISE COMING FROM LEFT REAR BRAKES. HARDWARE IN LEFT REARDRUM THAT HOLDS SHOES IN PLACE CAME APART INSIDE DRUM. HARDWARE MUST BE REPLACED, DRUMS AND SHOES MUST BE REPLACED.
    I am looking for a how-to guide for this job. Any help will be appreciated.
    Thanks...
    #1 SamEgel, Jan 24, 2015
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    #2 valde3, Jan 24, 2015
    frodoz737 and Mendel Leisk like this.
  3. Mendel Leisk
    42,240
    I'll do disc brakes with no qualms. Drum brakes, while very reliable, when they need opening up, I leave it to the pros. I've done it once, took me forever, didn't have the know how and the right tools. Wrestling with the springs and myriad parts is not a lot of fun.
    Get a quote from the deslership?
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    You'll need mini VCI cable & techstream software (avail on Amazon or eBay), b/c the rear cylinders will need to be bleed.
    I've never been able to remove the shoes w/o moving the rear wheel brake cyl piston.
  5. SamEgel
    Valde thks a lot. How do we turn off ECB? Which two relays will be removed? I suppose one is the skid control near the 12V battery right? What is the other?
  6. valde3
    2,002
    750
    Finland
    It says it right at the link that I gave you.
    "If the car was just powered up, wait at least two minutes after power-off
    for the brake system to go through its shutdown self-test [part of which
    involves repressurizing the brake lines]. Then, pull these two relays in
    the under-hood block. Pump the brake pedal slowly, holding it down at the
    pushed position for a short time, until that little high-pitched beeper starts
    going off under there."
    And it has picture of what relays to pull. Relays will just pull up.
    Intuitionx2, SamEgel and frodoz737 like this.
