Rear brakes are wearing out every couple of thousand miles. What am I missing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhman2006, Apr 1, 2017.
  1. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
  2. Mendel Leisk
    41,463
    If he's in there lubing the pins it'll be with the calliper off, might as well get the piston oriented right.
  3. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Yeah I'm gonna try to get both of those done together. Just wondering if it'd be worth getting new caliper or lubing the pins+the boot should be sufficient.
  4. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I took the car to a trusted mechanic to figure out whether it's really frozen caliper or something else and this is what we found out --- The pad that was touching the pin (inner pad) was pretty much brand new, but the pad that was on the outside (on the wheel side) was pretty much worn out. Worst of all it was worn out very unevenly. The mechanic thinks it's because one of the pins that's mounted on the caliper isn't well lubricated. Even though I trust him and he does great work, I don't think it's very familiar with hybrid system. Any thoughts why the pads are wearing out unevenly? I've attached a picture.
  5. bisco
    51,946
    i think he nailed it. there's nothing 'hybrid' about the brakes at that end of the system. driving in boston area means tons of salt, and requires constant vigilance/ keep the pins lubed, and you should be fine.
  6. Mendel Leisk
    41,463
    For the brakes to operate properly the caliper has to be able to move side-to-side on the rotor. That's made possible by properly lubricated and sliding pins. What does your mechanic say about the pin condition?
    BTW: Toyota USA recommends 30K miles or 36 months to do this.
  7. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    That's weird though. I also have a '05 Prius with 110K miles on it. It never that this type of problem. The only break related thing I did was replacing the brakes at 100K miles. So far my '11 Prius has already went through 2 pairs of brake pads; with only 55K miles on it. Kind of frustrating.
  8. bisco
    51,946
    the '05 has rear drums, not an issue. one of toyota's biggest blunders was to go to disk brakes in the rear.
  9. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    He said the pins look fine. He took both of the pins off and both of them looked pretty much brand new. However, he couldn't figure out why one of the pins were moving freely when the other one required a little more "pull". He just wiped them off nicely, lubed them, and put them back in.
  10. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Ah, that's what it is. Toyota definitely should've stuck with those.
  11. bisco
    51,946
    the problem is, rear brakes don't get much of a workout compared to front. with 4 wheel disks, the rear always suffers.
  12. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    So every 30K miles I have to take the wheels off and check on those pins? Toyota definitely didn't think this through.
  13. Tande
    Tande Active Member
    539
    322
    Mich.
    FWIW.......we each (wife & I) have a 2010 gen. 3.......I could lube the pins weekly & the pads still would not wear evenly (both vehicles)......when I would pull the pins they would be "Stuck" (with lots of lube)......finally removed the pin rubber dampers; (front caliper pins don't use) decided they were to much an interference/fit & were literally sticking to the bore in spite of the lube.......uneven pad wear issue solved.......YMMV
  14. ChapmanF
    18,213
    Aren't you rotating tires more often than 30K anyway? When the wheels are off, just move the calipers back and forth.
    I find my pins will get just a little bit ... glopped in place ... in the time between rotations. The ordinary motion of the caliper during braking is so slight, they really don't move much, and the grease gets a bit hard. Just slide them in and out a couple times, grease loosens up, you can feel whether they seem juicy or dry, if they don't feel dry or rough, you're done.
    You don't even need a wrench for this. The rotor just sits on the hub; nothing holds it there with the wheel off (except, often, rust). You can slide the caliper back and forth enough to loosen gloppy grease without even undoing the bolts, just by letting the rotor wiggle too.
    If the rotor's too stuck with rust, you might need to loosen it with M8x1.25 bolts into its loosening holes. If you wiggle it during tire rotations, though, it may never get that stuck.
    But, back to this particular thread ... stuck pins aren't the only way for a caliper to drag. If the pins look fine and it drags anyway, then some attention to the free motion and return of the piston could be needed.
    -Chap
  15. Mendel Leisk
    41,463
    Still, if one pad is wearing like crazy, and the other is like new, it seems to me it must be caliper not "floating" properly. Somehow. Maybe a clue: it is the pad on the opposite side from the piston. Something is going on.
    dhman2006 likes this.
  16. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Haha. That's the million dollar question or in my case $100 (pads+rotor). But everytime I changed those pads, I noticed the pad on the opposite side from the piston is wearing unevenly.
  17. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I may start doing that. Usually I go to the dealer to get the oil change done and they rotate the tires for me. I'm going to tell them to start looking at the pins/ caliper when they rotate the tires.
    Thanks for the tip, Chap
  18. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Are you saying the front brakes don't have those rubber boots? That's interesting. Never looked at the front ones that carefully since those never caused me any headache, but it's certainly an interesting find. Thank you.
  19. ChapmanF
    18,213
    And if the pad, on the dead side of the caliper, is wearing unevenly (I'm taking that to mean, "in some weird angle or pattern", not just "a different amount than the other pad"), and it keeps happening after replacements ... then basic mechanical questions might come up, like, are the bracket, axle, and/or hub bent in some way and not properly aligned ... could the bracket have been removed at one time and replaced with a piece of grot between the mounting surfaces? ... that kind of thing.
    -Chap
  20. Mendel Leisk
    41,463
    Looks like maybe one pin is hanging up. See the pic of the pads up the page: the wear all on one pad, AND beveled end-to-end.
