Rear brakes are wearing out every couple of thousand miles. What am I missing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhman2006, Apr 1, 2017.
  1. Mendel Leisk
    41,463
    Front and rear pad pins are similar, both have a rubber boot where the pin goes in.
  2. Rennie
    Rennie Junior Member
    31
    Australia
    Did you get to check that pin?
    A bit of silicone grease may help with stuck calipers if the old grease is gone.
    C6903 using PriusChat mobile app
  3. Rennie
    31
    Australia
    Forgot to read the next 3 pages :-P
    Also, Australian 2nd gen Prius has rear disk brakes. "Handbrake" is a drum. So it has both :-P
  4. Mendel Leisk
    41,463
    It's confusing: OP's car is second gen, but the vehicle with brake problem is third gen, has rear disk brakes.
  5. Patrick Wong
    18,210
    6,510
    OP owns at least two Prius: 2005 and 2011.
  6. Mendel Leisk
    41,463
    Patrick, just noticing: you're going to run out of fingers, to count your vehicles.
  7. Patrick Wong
    18,210
    6,510
    :D
    The 2007 belongs to my daughter but I leave it in my signature since I continue to accept responsibility for maintenance beyond oil changes which she has done at her local Toyota dealer...
  8. Tande
    Tande Active Member
    539
    322
    Mich.
    Both F&R have caliper/pin/rubber/boots......only R has caliper/pin/rubber/dampers
  9. Mendel Leisk
    41,463
    Not sure what dampers are? (n) Anti-squeal springs? That is different, not present on front. Here's some exploded views:
    Rebound likes this.
  10. Tande
    Tande Active Member
    539
    322
    Mich.
    Interesting! ......that diagram doesn't show the "Dampers" (my terminology)......they are in fact a rubber sleeve/bushing/damper that is located on an undercut on the far/end of the pin.......like I mentioned "Interesting".......wonder, if they have been eliminated?? :confused:
  11. Mendel Leisk
    41,463
    Yeah full brake section (PDF format) is attached to post 41, have a look. Pins and boots are similar, front and rear. Rear has addtl anti-rattle springs, and of course the tricky calliper piston due to parking brake incorporation.
  12. Tande
    Tande Active Member
    539
    322
    Mich.
    Ya, the diagram calls out a "Rear Disk Brake Bushing Dust Boot" & then points to the dust boot.......the "Damper/Bushing" is a separate piece that "Stays" with the pin........I don't see it
  13. Tande
    Tande Active Member
    539
    322
    Mich.
  14. Mendel Leisk
    41,463
    The smaller pieces are the bleed bolt caps? (n)
  15. Tande
    Tande Active Member
    539
    322
    Mich.
    Nope......they're the rubber/damper/bushings that install on the end of the caliper pins, that I have been discussing (ref.post #33)
  16. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Correct. I own 2 Priis (I think that's the Prius plural I've heard) - '05 and '11
  17. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    So you took those little dampers off, not the pins though
    I meant the rubber boots. You took the dampers off, not the boots?
    #57 dhman2006, Apr 11, 2017
  18. Tande
    Tande Active Member
    539
    322
    Mich.
    Yes.....now they are the same as front......no dampers
  19. Mendel Leisk
    41,463
    I'm very sceptical. Have had the pins out front and rear, they all have square-off ends, no sign of dampers. Toyota Online parts doesn't mention them, ditto for the exploded view in Repair Manual. I suspect those are bleed bolt caps.
  20. Tande
    Tande Active Member
    539
    322
    Mich.
    Not wanting to argue, BUT......I too, have had my pins out MANY times & can tell you, my rear pins do in fact have rubber dampers/bushings/ whatever you want to call them, which I removed......that is one of the things we are trying to determine; do all Gen. 3 have them?? ......I do agree with you on the "Red" above......negative on the "Bleed/Bolt/Caps"
