Rear bumper loose
Discussion in 'Gen 4 Prius Main Forum' started by alexendra, Jan 2, 2016.
  1. alexendra
    alexendra Junior Member
    17
    17
    Kaohsiung,Tawain
    In Taipei Autoshow 2016, a Taiwan Hybrid Club member found the Prius 4gen still has rear bumper loose sitiuation such as P3. Prius Rear Bumper Cover loose and gap? | PriusChat
    The bumper seems used the same material as P3's
    #1 alexendra, Jan 2, 2016
    pakitt likes this.
  2. Hector Orellana
    Hector Orellana New Member
    Mission Hills, CA
    How can we get together to fix this problem? I own a 2015 Prius and have the same issue, and Toyota refuses to fix it stating that it is not a Toyota issue.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Panel gaps on PRIUS aren't as good as my previous THAI built FORD, or a KIA RIO before that. But MUCH better than a South African build FORD in between. I've come to realise that things like panel gaps on consumer cars aren't always going to be perfect. Different if you're into a prestige car, when the expectation is higher (ie you'd expect a LEXUS to be better than a TOYOTA - and if the TOYOTA was perfect, how can LEXUS possibly be better?).
    RCO likes this.
