Rear Camera 2016
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by tigerpilot, Jul 19, 2016.
  1. tigerpilot
    tigerpilot Member
    144
    Naples FLorida
    Hi:
    It seems like the rear camera has suddenly started to point down more that it used to. We have three Prius's and none of the older one are like this.
    The dealer tells me he hears this problem all day long and there is nothing he can do about it.
    Wondering if anyone else has noticed this issue?
    Thanks, Don
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    Bull... It is the dealer's problem to figure out how to solve the problem
    alanclarkeau likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The manual has a description of a few situations you could check - like a heavier load in the back, or the boot not closed properly. Check the manual - and if that doesn't help, go back to the dealer.
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Luckily, my camera has not moved in 5 months of ownership. Could it be due to closing/slamming the hatch too hard? I open & close my hatch twice a day (to remove/install the heat shield) and I make sure I am very gentle when closing it.
  5. Frolix
    Frolix Junior Member
    45
    22
    Here
    Isn't there a setting to correct for this in the service menu ?
    kithmo likes this.
  6. booke02
    391
    415
    Israel
    I was looking at the camera mount on my car - it looks pretty solid - I can't imagine it moving even if you close the hatch quite strongly
    krmcg and alanclarkeau like this.
  7. tigerpilot
    tigerpilot Member
    144
    Naples FLorida
    The boot nt closed properly would make the camera read high and there is nothing in the rear. Car has 5000 miles on it. I'm going to call Toyota to see what they might know.
    Thanks, Don
    Hi:
    None of those would cause the angle of the camera to change
    Thanks to everyone.
    I just left the dealer and checked on a new Prius and it's the same. We're just getting old I guess.
    But.....the outside temp reading is ALWAYS 3-4 warmer that actual even after sitting in the garage overnight and I'm having a problem getting them to do anything about it. I was pretty sure there is a tech stream adjustment for this but I need some kind of proof for them to look it up.
    Naples FL (3 Prius's at the present time. '09-'15-'16)
  8. booke02
    391
    415
    Israel
    It is one of the adjustments that is available with Carista - you can change the offset for both inside and outside temperatures by a couple of degrees in either direction.
