Rear collision system questions
Discussion in 'Gen 4 Prius Main Forum' started by Gen 2 Tom, Jun 9, 2016.
  1. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I finally had the system beep, as I came up rather fast on almost stopped cars. I'm not sure if I was on the brakes or just hit the brakes as it beeped. I didn't feel the system apply any brakes.
    Would it apply more brakes even though I was on the brakes? How long after the beep would it try stopping the car? What sensor does it use for this, radar or camera.
  2. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    Could it be you mean the pre-collision system (PCS) of the TSS?
    As you probably know, the Rear Cross Traffic Alert, uses radar sensors mounted on the rear corners and is active when backing out from a parking spot.
    2016 Prius - the next generation of Toyota's technology ambassador - Toyota
    Jan
  3. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Sonar sensors. Radar sensor is for DRCC and is behind the Toyota logo on the front of the car.
  4. Tideland Prius
    16,670
    RCTA uses millimetre wave radar mounted behind the rear bumpers. The sonar sensors are for ICS and SIPA.
  5. Tideland Prius
    16,670
    The system will do a number of things
    1. Beep and flash "BRAKE!" on the screen (which you heard)
    2. Prime the brake pads by moving them closer to the discs, reducing the distance and time needed to apply the brakes
    3. Prep ABS and Brake Assist for when you eventually hit the brake pedal
    From here on, there are two versions
    Version 1: You respond and hit the brakes
    • Depending on how fast you respond (i.e. how fast you lift off the accelerator and how fast you depress the brake pedal), Brake Assist may or may not come to your assistance. Brake Assist just helps you apply greater braking force if the computer determines you're performing an emergency brake but you're not pressing the brake pedal hard enough.
    • Assuming you're braking hard enough from a higher speed, Pre-Collison Seatbelt will then tighten the front seatbelts so that your upper body doesn't move forward under braking. This means you're properly seated to manoeuvre around the object if necessary or should the worse happen, it minimises the chances your face will hit the airbag.
    Version 2: You don't respond and a collision is imminent
    • If the car determines a collision is imminent and you didn't respond, Pre-Collision Braking will take over and apply the brakes fully to bring the car to a halt. PCS reduces the speed by up to 40km/h (25mph).
    • Pre-Collision Seatbelt will also tighten the front seatbelts.
    So to answer your questions
    1. Yes it will apply more braking force if it thinks you're not braking hard enough (Brake Assist. This is standard on practically all new cars)
    2. How long after the beep? It depends on how fast you're approaching the object.
    3. It's using the radar mostly. The camera is used for pedestrian detection (and lane departure alert) but I'm not sure if it's also used for vehicle detection for the PCS.
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    See, the tin foil hatters were right! Big Brother IS watching! ;)
  7. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    So does it stop the car before impact? Sounds like no to me.
    Also does the rear cross traffic system apply brakes?
    Tin foil is required for all pedestrians for this car to work correctly.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The demonstrations have all shown that it DOES stop the car before impact. But NOT in reverse - it just alerts you to cross traffic.
    -> the demonstration starts at 2:20.
    DonD and ETP like this.
