Rear dash cam wiring run - experience? (FitcamX)
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Zeromus, Feb 10, 2024.
  1. Zeromus
    Zeromus Active Member
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Hey all
    Wife has always said she wanted a dash cam when we got any new car, so I ordered the FitcamX. I love the clean OEM look, and the fact all wires are easy to hide on existing connectors, meaning no splices or wiring runs for that.
    Curious if anyone has run a rear dash cam wire in this car yet. I'm not sure if I can run it along the headliner the whole way, due to the side curtain airbags. Which means I probably need to run it down the pillar then up the side trim to the hatch in the back, right?
    I haven't found any videos or photos for the gen 5 online yet for this kind of project, so wondering if others have any experience before I run the rear cam wire. Front cam I have zero worries for
  2. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    My FitcamX arrived last week. Just waiting for temps to warm up before installing it. The only video I've seen is the one on the website. If it looks like a project I don't want to handle, I may opt to pay an installer to do it.
  3. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Have Viofo 229 Plus with rear camera. Will install it in a week or two.
    Installed a similar Viofo 2-camera on a Gen 3 Prius. Used plastic pry tools to tuck the rear camera cable into the molding around the windshield frame. Then into the separation between the headliner. Other than where the cameras plug in, the cable is entirely hidden. Expect the process will be largely the same on the 2024.
    Only issue was that after a few years, the strain on the rear cable when the rear door was lifted eventually wore through the cable. Will be attaching some strain relief and wrapping that section in cable protection.
    Zeromus and vvillovv like this.
  4. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Do you have side curtain airbags? For me, I just don't want the cable to be run right in front of those, as it probably interferes with the safety system. Down A pillar airbags, I know you're supposed to run wires along the factory harness which is clearly running a seperate side of the pillar.
    The owners manual shows that there are airbags somewhere along the upper rails of the car, so that's what I'm curious about :/
  5. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    The rear camera wire could be run down across the floor, tucked into the molding there. But that would require the cable be run down the a-pillar, both sides of which have airbags.
    Don't see any real issues tucking the wire between the seam where the headliner meets the doors. Airbags are extremely powerful. A thin USB cable isn't likely to factor in their deployment.
    The alternative would be to remove the headliner or molding and run the cable behind the airbags. Some installers use this process, but it involves working with the airbags, moving them around to run cables behind them.
    To me, that seems more risky than just tucking the cable into the seams.
  6. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    True. Though my concern isn't the airbags failing to deploy. Quite the opposite, it's the airbags pushing/snapping/pulling the cable and the cord being thrown towards passengers at the speed of an airbag being deployed.
  7. wrtboy168
    wrtboy168 Member
    70
    29
    Northern California, USA
    2024 Prius
    any idea if the fitcamx works with the prius le? i'm only brave enough to consider the front 4k camera. :D
  8. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    I got a bum unit, but, the shroud fit and should work just fine with your LE since it worked with my prime.
    I just got a unit with a bad SD card slot so they're shipping me a replacement now.
  9. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    The Viovo models have substantially better image quality and better functionality, at a lower price.
    Downside is that they are not integrated. But if installed properly, they are hardly noticeable.
    Note that the LE trim may not have usable power in the rear view mirror housing, as there is only a TSS power plug, not the mirror power. Because of this, power adapter firm Dongar states that their adapter will not work with the LE trim. If not, then any dashcam power on an LE will either need to be hardwired from the fuse box with the power wire tucked behind the windshield and a-pillar, or a dangling cable to the 12v cigarette lighter.
    #9 Lantaral, Feb 13, 2024
  10. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    do the le and prime share the same cover? fitcamx site shows the cover is to replace cover part 86466-47070. i did a 'make sure this part fits your vehicle' on autoparts.toyota with my vin number and it came back 'may not fit your vehicle. tried checking with the prime and it also came back as 'may not fit your vehicle'.
  11. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Would send a message to Fitcamx. The higher trims have more ports and internals under their cover, so wouldn't be surprised if the LE cover has less depth. But the attachment points may remain the same.
    Edit: Would also ask them whether the LE's power port under that cover is compatible with their product. The LE only has a TSS power port under that cover. Dongar makes a dashcam power adapter for use in Toyotas. But it is not compatible with the LE as it can only shunt power from the mirror, not the TSS.
    #11 Lantaral, Feb 13, 2024
  12. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    i had to look up what is tss. :D page 2 of the toyota tss pdf file has more information on the dynamic radar cruise control aka drcc. i'm wondering if it's the same acc (adaptive cruise control) fitcamx mentions in its site.
    Real Plug and Play
    FITCAMX dash cam has brand-new methods for power from Adaptive cruise control (ACC) sensor with hidden wiring and easy installation with the method of plug to plug. No need to remove A-pillar and connect the car fuse box and the cigarette lighter.
  13. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    I have a prime SE and it worked just fine in terms of fit.
    The little plastic tab that attaches to the shroud is a bit different from FitcamX, it has a slightly bigger hole for the mirror, probably to accommodate the digital mirror option and to allow for the cables to fit better?
    Even the Canadian base Prius isn't the same as the US LE. I think we only get the AWD mid and top trim equivalents here.
    wrtboy168 likes this.
  14. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Ran the rear wire today.
    Taking off the back trim was easy, and used a fish wire to pull the cord through the grommets then along the wiring along the driver side at the bottom to match the factory wiring harness.
    With the fish cord quite easy actually.
    Just need to be careful with the passenger trim with weatherstripping. They're actually attached together at a clip. And run the wire behind the rear passenger airbags.
    Of note - the wiring grommet has clips on it, denoted by little dots. Pushing in on one side to release it the other side wiggled out very quickly with no hassle
    Update:
    For all that is holy try not to to remove the a pillar clips far at all. At. All.
    The clips that hold it in place so the plastic doesn't fly into your face, when the airbags go off are a ***** to get back on. Absolutely, miserable. Just try very hard to, at best, peel it back just enough to see where the line fish is going. Not enough to come off the clip fully. My.....
    #14 Zeromus, Mar 10, 2024
    otatrant and patmine23 like this.
  15. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Small update: all works great. The A pillar trim didn't seat perfectly by the speaker grille.... I need to fix that when I have the time and patience to not scream at the clips.
    Ideally, you remove the A pillar clips and put them on the trim then put the trim on the car. I found a YouTube video detailing these clips on a different car. But the little release tabs are so tiny and so far back they're very hard to remove.
    So yeah, don't pull off the a pillar cover if you can help it. The trim catch clips are honestly infuriating. There's a long bit of plastic that fits into a pocket of the trim that needs to be fed in, while the clip (that can turn) has to not move at all, and then it can clip into the trim.
    Removing the clips entirely involves pressing two very thin tabs on the lower part of the clip, next to the sheet metal, almost underneath the body of the main clip itself. Maybe if I had a pair of angled very thin and long pliers it would work. But I don't have this tool (yet, I will inevitably have to get one)
    As for the hatch, it was very easy and no issues. I will have to go back in with some small glue on clips to secure the cable to avoid potential rattling, when I also go in this summer to add some sound dampening sheets.
    The car has quite a bit of underlayment actually under the carpet, and it's thick, so that's definitely helping with sound at the front. There's also a very wide channel for the side airbags that is easy to fish wire through to follow on the rear seat airbag area - I didn't lift the trim because I wanted to be extra careful with the airbags there. But following the wiring was very simple, and the existing factory clips for wiring harness can hold the cable very well. Only part I had to zip tie to avoid loose wiring was when I got to the driver side footwell, as the factor harness terminates in that area and there is less factory clips to piggy back off of when fishing the wire upwards.
    I'd rate the install of the FitcamX very easy. Just time consuming for the rear cam. If you get the front cam only, it's honestly trivial. Just ensure the car isn't cold, so that the trim cover doesn't snap when pushing it back on, and make sure all the wiring bundle is outside the little plastic trim opening when sliding on, then stuff it in *after* to finish it off. This avoids wiring pinching or getting in front of one of the clip paths which can snap the plastic clip due to the pressure involved to put it on.
    Love the quality, I'll post some clips this weekend if I get the time.
    Worst part really was just the a pillar. The slope and construction is very narrow so it is very hard to fish the wire, tight behind the factory wires, and put the trim back. If you have the right tool, it would be significantly easier to anyone doing this in the future.
    - final comment: if you don't have the digital mirror, the FitcamX secondary shroud clip (that covers the wires and the rear view stalk) is actually too small of an opening. The factory trim has a larger hole for the rearview stalk, so it has a greater range of motion, and if you push the stalk too high up with the FitcamX one, it pops the trim off. The whole piece with the way the angle works, not just the small piece.
    Chances it's ever an issue are low, but I've reported it to FitcamX and they've asked me to take photos of both pieces (theirs and Toyota's), so maybe there will be a revision. The Toyota trim piece doesnt fit as it's male end clip tabs are different and don't slip into the FitcamX female clip receivers.
    If anyone has more questions about FitcamX and gen 5 I'll be happy to answer
    Sorry for double posting and if this isn't super clear, trying to sneak it in on my work break before the freshness of the task is lost for me
    #15 Zeromus, Mar 11, 2024
    Pierre_Coop likes this.
  16. Object6732
    Object6732 New Member
    vancouver
    2024 Prius
    Limited AWD-e
    I unfortunately am encountering the same fate. Have you been able to put it back on?
    For other people wondering, the pillar clips are almost exactly like the one here:
    Once it detaches from the long bit of plastic, gotta take the whole thing off to put it back on properly
    I will continue at it once I find a super-long nose pliers. The video makes it looks easy for the RAV4 but there is literally no space to use regular pliers (pic below)
    One solution I am thinking is to just snip the plastic bit, and buy new ones (part # 6221711020 I believe). Only ~$8
    Or take it to the dealership, which might cost a lot more
    otatrant likes this.
  17. Hammersmith
    Hammersmith Senior Member
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Toyota considers it a non-replaceable part; probably for that reason. I snipped mine and bought replacements when I had to remove both A-pillars to pull my dash.
  18. Zeromus
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    You can use really long pliers to pinch it at the frame of the car to remove it. I bought some to do it myself.
    If you have them then you can get it back on. It doesn't rattle but it does leave a little misaligned gap if you don't replace them.
    And you can pull it mostly off, to give you room to work, without removing them entirely. But trying to get them back into seated position is going to be a pain in the nice person - doable though, if the goal is to drive for a few days until you can get the new clips.
    Pliers make it much easier to reseat them. But, the plastic kinda bends funny once it gets removed so you need new clips at the end of the day to make it fit nicely like it did before.
  19. Object6732
    vancouver
    2024 Prius
    Limited AWD-e
    I see, the video made it seem re-usable. I think I should just snip it then and save time. Could you confirm if the replacement part number is correct? #6221711020
    Good to know, thanks. I will try it out with pliers while waiting for new clips.
  20. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yep, that looks like the correct part number. A whopping $4.37 each if you buy from the right dealer. But I think I also paid about $8 each because I wanted them quick and my dealer could have them by the following day.
    Object6732 likes this.
