Rear defogger problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TSaxman28, Oct 12, 2008.
  1. TSaxman28
    TSaxman28 Wandering Minstrel
    47
    NH
    2019 Prius
    A couple of weeks ago I noticed that the rear defogger wasn't working in the top (big) window. It's working fine in the lower (small) window. I took it to the dealer and they tested the elements and found that the correct voltage was present. However the defogger is still not clearing the window when it's been fogged up in the morning.
    Any suggestions on how to proceed from here?
    Thanks!!
  2. EZW1
    EZW1 Active Member
    719
    79
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Voltage at the contacts but no heat from the element? Obviously an open element. Which means a new window.
    I'd ask the dealer to check the resistance of the element, or even you do it. Don't know what it should be but you should see something other than an open circuit.
  3. TSaxman28
    47
    NH
    2019 Prius
    Thanks. I'll try to compare resistance of elements on bottom glass with top and see if there's any difference.
Loading...
