Rear disk premature wear
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CivicQc, Apr 22, 2012.
  1. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    I searched this site without finding an answer to this.
    When I changed my tires last week, I noticed the rear disks had a groove in it. That seems to be a sign of wear, but having never checked that before, I do not know whether that is new or not. Note that my front disk are totally fine - nearly as new.
    I was expecting the Prius brakes to last a for a long time, because of regen braking... Moreover, I was expecting the front brakes to wear more quickly, not the rear ones.
    Did any of you notice an unexpected wear of the rear disks w/r to the front ones? Is that normal, or could it be that my rear brakes are not adjusted properly?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Depends on how deep the grove. If you run you finger nail over it, does it get snagged? Minor groves are normal. I would suspect all you need it to have your rotors turned to remove the glaze. Some shops do that for free.
  3. El Dobro
    El Dobro A Member
    7,106
    3,282
    Did you look through the hole in the rear calipers to see how much of the pads are left?
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Depends on your mileage as well.
    If you have 2,000 miles and it's a deep groove then it's a problem.
    If you have 86,000 miles and it's a minor groove then it's not a problem.
    If you don't do many miles and leave the car outside then the rear brakes do seem to rust up easier. There are ways to remove this rust, such as, after making sure there's nobody behind you, press on the brakes quite hard and bring yourself to a quick, but safe stop. This should burn the rust off - just be careful!
  5. CivicQc
    233
    99
    Planet Carbon
    Thank you all - I will check the pads and disks again this evening and come back to you.
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Rear disc brakes are more prone to get debris (sand, gravel, etc.) trapped between the pad and rotor.
  7. JayR
    JayR Junior Member
  8. JayR
    JayR Junior Member
    I concur with CivicQc. I've been driving my 2012 Prius for 35,000 Kms and I also noticed that the rear brakes are wearing faster than the front. What's the point of regen braking (from the front/traction wheels) when the back brakes are going against regen with friction braking. Maybe it has something to do with security i(n case of an emergency stop) or is it an unbalanced adjustment between front and back brakes ? I'll bounce this off the dealer to see what they come up with.
  9. Mendel Leisk
    42,361
    Could also be due to forgetting the parking brake release.
  10. GregP507
    GregP507 Senior Member
    3,002
    481
    I've seen mud lodged between brake-pad and rotor causing rapid degradation of the brakes. Not something I've experienced, but a friend with a similar '06 Dodge Ram had them fail at less than 2 years of use. Mine actually went over 100k before I needed the pads replaced.
    I'm also wondering about the expected lifespan of the Prius brakes. I haven't found any good information so far. I know the brakes engage at low speeds, because I can feel the pads skipping on the rotors at a traffic light. But my question is how much do they actually wear during normal driving? I've retrained myself not to downshift to "save the brakes" anymore, using the brakes for regeneration instead, but are they good quality brakes which should last forever, or are they a cheapened-up version, designed for occasional use?
    I'd like to know how much wear to expect from my brakes. Thanks in advance.
    #10 GregP507, Jul 7, 2014
  11. GregP507
    3,002
    481
    It's hard to ignore the warning light and beeper when you drive with the parking brake on. I'm not sure why there's no lockout, which prevents putting the car in "drive" when you try to go with the parking brake on, but it does happen however. I did it myself for a short distance. There is certainly a lockout preventing using the VTR function on the display screen, which is disabled unless you have the parking brake engaged.
    Perhaps it better serves the interests of Toyota to prevent distracted driving accidents, than it does to help avoid replacing brake-pads which are worn out due to the driver's own carelessness.
