Rear Door Step?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by schmuber, Jul 23, 2019.
  1. schmuber
    schmuber Member
    115
    85
    Georgia
    The trim piece that's at the very bottom of the rear passenger side door opening came loose due to broken pins. I have no idea what it's called, so if anyone with better knowledge of Toyota parts catalog could look up the name of it and a part number (2010 Prius), I will be eternally grateful.
    Again, that's the piece that you pry to get access to various wires (or to route your own). Mine was basically destroyed by thousands of drunks (I'm an Uber driver) tripping over it.
  2. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    The part you're looking for, I think, is called "rear sill trim", and available online for around $60 per side. Part numbers vary by color:
    -LH light gray: 67918-47041-G0/RH light gray: 67917-47041-G0
    -LH bisque: 67918-47041-E0/RH bisque: 67917-47041-E0
    -LH gray: 67918-47041-B0/RH gray: 67917-47041-B0
    schmuber and jb in NE like this.
  3. schmuber
    schmuber Member
    115
    85
    Georgia
    Just to make sure: LH means driver side, correct?
  4. Vman455
    540
    556
    The Middle
    Correct, as you're facing forward the same direction as the car.
    schmuber likes this.
