Rear doors do not unlock
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CarmelPrius, Dec 4, 2012.
  1. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    Every time I shut down my PIP, the rear doors are locked. I've checked the child lock and it's ok. I've checked the settings (on the nav. screen) regarding the door locking/unlocking options for the vehicle, when putting it in park, etc.
  2. lensovet
    2,615
    496
    Burlington, NJ
    how are you unlocking the doors?
    if you unlock the doors via SKS and only touch the driver's door, all the other doors remain locked.
  3. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Unless you've changed it. I touch the driver's door, and all doors unlock.
  4. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    From Manual page 117:
    Switching the door unlock function
    It is possible to set which doors the entry function unlocks.
    Step 1 - Turn the “POWER” switch off.
    Step 2 - When the indicator on the key surface is turned off, push and hold
    or for approximately 5 seconds while pushing the button
    on the key.
    The setting changes each time an operation is performed, as shown below.
    (When changing the setting continuously, release the buttons, wait for at
    least 5 seconds, and repeat Step 2 .)
    Driver Door Only Opens
    Unlocking doors Beep
    Hold the driver’s door
    handle to unlock only the
    driver’s door. Exterior: Beeps three
    times
    Interior: Pings once
    Hold the passenger’s door
    handle or back door
    opener to unlock all the
    doors.
    All Doors Open
    Hold the front door handle
    or back door opener to
    unlock all the doors.
    Exterior: Beeps twice
  5. lensovet
    2,615
    496
    Burlington, NJ
    right
  6. bisco
    52,614
    i don't think there is a function where both front doors unlock and back doors stay locked. also, the doors should not lock when you power down.
  7. lensovet
    2,615
    496
    Burlington, NJ
    Right, but if auto-lock and auto-unlock is turned off and SKS settings are left at defaults, the front driver door will unlock and everything else will stay locked. That's what I suspect is happening with OP.
  8. bisco
    52,614
    perhaps they don't realize that the front passenger door is also locked. the way the post is stated makes it hard to understand. there have been many posts over the years stating, 'when i unlock drivers door, other doors do not unlock'. or, a question, 'how do i make all doors unlock when i unlock drivers door?'.
  9. CarmelPrius
    49
    Maine
    When I set the doors to unlock when putting vehicle in park, I failed to save the selection. I re-did it today and now it works properly.
    lensovet likes this.
  10. bisco
    52,614
    excellent! thanks for following up.
