Rear Drivers side drum not engaging
Discussion in 'Gen 2 Prius Technical Discussion' started by joejo, Apr 25, 2013.
  1. joejo
    joejo New Member
    2006 prius 130k
    I replaced the rear drum brakes, wheel cylinders, and bled the brakes. I discovered on drivers side, that no matter how much bleeding, the brake does not engage on the rear drivers side. While bleeding, I discovered very little pressure. The brake light, VSC, ABS, and ! lights remain lit while the cars on. Does this sound like a master cylinder or ABS failure? Can the autoenginuity scan this issue?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    Try getting the blink codes from the ABS system. You short pins 4 and 13 of DLC3, and watch the blinky lights on the dash:
    ABS, VSC Lights... Weird!! | PriusChat
    That will eliminate some guess work. Don't know about Autoenginuity, but the mini VCI does the brakes.
  3. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    If you tried bleeding the brakes the same as any other car that is the problem. As nh70 said you need the mini VCI and a laptop with Techstream software "comes with VCI" to do the job successfully.
    John (Britprius)
