Rear floor mats won't stay down :(
Discussion in 'Gen 4 Prius Main Forum' started by Chris Wolfgram, Nov 2, 2019.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    412
    167
    Sacramento CA
    2019 Prius
    And this is a major PITA when I gave to constantly be struggling trying to twist them back straight between rides. Anyway have an idea to keep these darn things on place ?
    In my last car, I had Weather Techs, and the rear was one piece that went over the hump. I sure wish these did. I'm about ready to order at least a new one piece rear floor mat, if I can't keep these from twisting and getting kicked around...
    49,492
    velcro?
    Tande likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Are they genuine TOYOTA? Mine came with the car and stay put perfectly - even with children mostly in the rear.
    kithmo likes this.
  4. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Yep. Genuine Toyota. Mine also came with the car, and are twisted around every time I check on them ☹️
  5. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    have you got them fitted in the correct sides ?
    krmcg and alanclarkeau like this.
  6. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Yep.
  7. bisco
    49,492
    the issue is rideshare. you're going to have to permanently secure them, or buy the kind with carpet tacks on the bottom.
    mine move around, but i rarely have rear passengers
  8. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    I know your right. Total PITA, but I appreciate there $$$
    Just trying to figure out a good, clean way to secure them.
  9. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    A couple of fat velcro (hook side) strips on the bottom surface of the mats should do fine.
    You might need to prep them to remove any mold-release compound; it’ll prevent many adhesives (like the velcro backing) from sticking. Usually warm soap & water does it.
  10. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    Yap, if you actually have rear passengers sitting there any substantial time, those floor mats do not stay put. I almost never use rear seats but still, the floor mats move around by occasionally placing my bags and other stuff. Putting velcro tape may work. But for a long term solution, your best bet is to replace them with one piece of construction like Weathertech. That's what I had to do with my Gen3 when I was still using the rear seats occasionally.
    #10 Salamander_King, Nov 10, 2019
  11. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Yep..... I've had two sets of Weathertechs in other vehicles and they worked great and stayed o
    Put.... Biggest reason though, was because the backs were one long piece that covered the center hump....
    Salamander_King likes this.
  12. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    T
    The problem there is that the backs are covered with those little spikes that I get are supposed to seat down onto the carpet....
  13. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    gotcha, they’ve already got a traction solution but it isn’t working.
    Yeah, just get the big 1-piece. My wife got one for ours. We probably only occupy the back seat 3-4 times a month, certainly less than a rideshare grind car but it’s been great. It’s a weathertech, and the fit seems much more precise than the ones for the front.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    I have two sets of mats, Toyota ones and an aftermarket set off Ebay. In both sets, the rear mats are a very snug fit and can't move at all, are you sure you have the correct rears, are yours a snug fit ?
    alanclarkeau likes this.
  15. Salamander_King
    10,975
    8,868
    New England
    OEM mats are very snug fit, it is not the shape or size that is the problem. Since they have no hook or snap like the driver side mat, If someone is sitting on the seat with their feet on the floor, the mat tend to slide very easily. OEM rear mats are more prone to this problem since they are smaller and there are no walls in front and one side of them. The exactly the same thing happened on my Gen3 OEM mats and current PRIME OEM mats. In fact, even the exact fit front passenger side floor mat is also prone to movement. It has no hook on it. Every time someone sit on the passenger seat, the mat shift forward creating a gap at the rear end of the mat,.
    #15 Salamander_King, Nov 11, 2019
  16. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Exactly !
  17. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Update; Problem solved.... I ordered the one piece rear floor Matt from Weathertech yesterday. I know it will stay put.
    Salamander_King, kithmo and krmcg like this.
  18. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Got my rear Weathertech today. It fits like a glove, and it cover the rear hump too
    krmcg and kithmo like this.
  19. BPC Auto
    BPC Auto New Member
    Three Touring
    I agree. Order the weathertechs. The fronts are perfect and easy to clean, but i have struggled with the rear like you, until I put the one piece rear weathertech floormats. then put the original mats on top of them. Since the original ones fit in the mold of the weathertechs they stop getting moved when you push your seat back.
  20. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Well, since you said this, I went on and threw the factory rubber ones in the back on top of the one piece Weathertech... I was only about a minute away from leaving them by the trash can at the waiting lot, but if they will stay put better now, I will keep them I guess. Thank you
    krmcg likes this.
