Rear hatch creak noise? (DIY fix)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by caymandiver75, Jul 22, 2013.
  1. caymandiver75
    caymandiver75 Member
    192
    101
    Northern VA
    2019 Prius Prime
    So I picked up a hatch creaking noise over the past 2 months that seems to have become worse with the summer temps and today I finally decided to do something about it. Seems as though every time the hatch (flexed) it made a creaking noise and it was annoying!
    If you also experience this noise I've found an easy fix. All you need is some high quality grease such as the stuff I use called Krytox GPL 205 Grease. Apply to all hatch contact points and voila no more noise! My car is finally quiet again. :)
