Rear Hatch Not Working.
Discussion in 'Gen 2 Prius Main Forum' started by dfairch69, Jul 1, 2022.
  1. dfairch69
    dfairch69 Junior Member
    38
    Ohio
    I have a 2008 Toyota Prius and it has sat since Fall 2021, recently rebuilt the hybrid battery with help from people on this site, which we're a big help. The rear hatch worked when parked but when I went to work on the battery I noticed the latch had stopped working I had to open it manually. I have changed the latch with a new latch from Toyota, not aftermarket, and replaced the door oscillator rear hatch trunk, replaced the fuse under the dash even though it was not blown and it still does not work. Anything I have missed? Has anyone else had the same problem? Thanks Prius Chat.
    49,534
    12v okay?
    fob battery?
  3. dfairch69
    38
    Ohio
    12 volt new this year. Latch will not work manually.
  4. dfairch69
    38
    Ohio
    Thank you.
  5. dfairch69
    38
    Ohio
    It was the FOB battery....I never would have known. I spent over $100.00 for a $3.00 fix.....thank you.
  6. Tombukt2
    Tombukt2 Senior Member
    9,237
    1,619
    Durham NC
    Yes they're all electric locks I don't think any of it's manual there's no cable to the trunk it's electric so you have an '08 or '09 with SKS you have buttons that you touch and they can open but I think the remote has to be live in order for all that to happen
    ColoradoCrow likes this.
  7. dfairch69
    38
    Ohio
    You two are right the FOB has to be active.....crazy.
  8. bisco
    49,534
    there is a cable in the trunk, and it is in the manual. i think it's a federal law
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,246
    5,944
    Columbia, SC
    Gen 2 has no cable. manual release requires removing a small plastic cover and rotating a small lever downward to release the latch mechanism.
  10. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    No cable. Thanks Toyota.
    There are a couple recent threads on PC however that show how to install one. Very simple to do.
  11. Another
    1,802
    511
    Naples, Florida
  12. bisco
    49,534
    cable, lever, what's the difference? they both let you open the hatch from the inside
  13. Another
    1,802
    511
    Naples, Florida
    You’ve obviously never had to use the PiTA internal lever or you would not say it’s the same as an external cable.
  14. bisco
    49,534
    i have used the internal lever, and i'm not comparing it to an external cable. what car has an external cable?
    i said 'there is a cable in the trunk', i forgot it was a lever.
    honestly, in 18 years, i've only had to open the hatch from the inside a couple times.
  15. Another
    1,802
    511
    Naples, Florida
    Once is more than enough especially when you have a full load of crap in the back that has to be crawled over and moved to get to the lever. Ridiculous design. The above fix that @AndyZaa proposed shows how a simple solution can be implemented.
    A release that is external to the trim in the back that hides the lever is what should have been offered by Toyota.
