Rear hatch rattle
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by utsug, Jul 23, 2019.
  1. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Due to rear rattle noise on my prius prime, brought it to the dealer to have them inspect it.
    They hear the rattle and confirmed its coming from the rear. But they can't find what's causing the rattle, so they said they will replace both rear shocks. Everything is still under warranty.
    Do u guys think they really tried or just decided to replace the rear shock.
    My concern is it might cause another issue in the future and i no longer have warranty. Currently @ 26k miles.
    Thanks.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Replacing the shocks will cause no problems (and you will have slightly newer shocks). You have established the warranty problem of a rattle in the hatch area, and if new shocks do not fix it they can keep looking. With your claim for the rattle prior to the end of the warranty period, they are obligated to keep working to fix that problem after the warranty period, because it occurred while in warranty.
    If the problem is not cured with the new shocks, immediately notify them so they won't claim it is fixed.
    utsug likes this.
  3. Tideland Prius
    16,564
    Mine rattled slightly but I don’t think it’s the shocks. It could be the bolts or it could be the CFRP itself. (Where the pieces are bolted together)
  4. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    after trying felt pads on those hatch stopper and other areas that seems to rattle, I gave up and brought it to the dealer. I think its not the shock either but they will replace it for free.
  5. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Update: Dealer replaced both rear shocks and the rattle noise is gone.
    But the dealer claimed that the spare tire which I attached behind the seat is the one causing the noise. I attached it using strap (with metal buckle) behind the rear seat where it latches to a piece of metal. but I told them that I removed the spare tire and it still has rattling noise. They even confirmed it that's why they decided to replace the shock.
    Anyway, so far no more noise.
    jerrymildred likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    Good job. You'd think they'd have removed it to see if that was it themselves rather than just saying that the spare was the problem without knowing it was the problem. BTW, I have my donut spare secured the same way and have no rattle. (y)
    utsug likes this.
  7. Dook
    Dook Junior Member
    40
    France
    Did they change this plastic piece (green circle) ? Both side ?
  8. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    No they did not. They replaced both rear shocks and the rattling noise is gone.
    Dook likes this.
  9. Dook
    Dook Junior Member
    40
    France
    Ok this piece then ? :D
  10. Dook
    Dook Junior Member
    40
    France
    Ok I understood (technical word can be confused), you changed both side of this part :
  11. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Nope. The dealer replaced the rear shocks.
    Dook and jerrymildred like this.
  12. Dook
    Dook Junior Member
    40
    France
    Oh OK, thank you, I was wrong !
    When you putted the ruber on the stopper and bumper, the noise stopped ?
    Because for me it did (the one where you answered in my thread) :
    Help ! Rattle noise from the trunk ! | PriusChat
    So for me it can't be the shock...
  13. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Nope it didn't. The new rear shocks removed the noise.
    Dook likes this.
  14. Dook
    Dook Junior Member
    40
    France
    Ok thank you utsug !
    utsug likes this.
