Rear hatch won't open after jump start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Boxo, Apr 14, 2022.
Tags:
  1. Boxo
    Boxo New Member
    Black Mountain, NC
    Hello, I have a 2010 Prius. I recently could not get the car started and had AAA come out, they started the car, using one of those portable battery packs connected to the battery. They said the battery checked out fine. The car seems to be running fine and everything works as normal except the rear hatch. The only way to open if now is with the manual release located in the back. I've seen were several other people on the forum have had this problem after a jumpstart but have yet to find an answer to the problem. HELP!
  2. PriusCamper
    PriusCamper Senior Member
    13,357
    5,398
    Pacific Northwest, USA
    See if you here any clicking sounds when you depress the button... If you do then the problem is mechanical, not electrical...
    Boxo likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Need new 12v battery
  4. Boxo
    Boxo New Member
    Black Mountain, NC
    The battery is just over 1 year old and the fellow that jumped the car said it tested fine.
  5. Boxo
    Boxo New Member
    Black Mountain, NC
    I'm not hearing anything when I depress the button, I can't help but think that something happened during the jump starting procedure that screwed up the system. I've checked for blown fuses, none found. I'm not really knowlegeable enough to trouble shoot the problem. I finally contacted the local Toyota dealer, $130 for them to diagnose the problem. Still hoping for a simple solution...
  6. Boxo
    Boxo New Member
    Black Mountain, NC
    I've just come across this youtube video with technology that I can understand! This may be my short or long term solution.
    ASRDogman likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Haven’t seen a battery test read “fine” on the display or print read out before.
