Rear Left Prius Brake Caliper Seized
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andreimontreal, Oct 21, 2019.
  1. Mendel Leisk
    42,355
    A link for OEM caliper. I'm not saying it's a good price, especially once you factor in the exchange and shipping. Plus, last time I checked, these guys don't ship to Canada. Still, useful for part numbers etc:
    Rear Brakes for 2012 Toyota Prius | Toyota Parts
    (Just checked: they still don't ship to Canada.)
    If it was me, I would get OEM, price be damned, to ensure 100% compatibility. But I appreciate considering the alternatives too.
    andreimontreal likes this.
  2. andreimontreal
    andreimontreal Active Member
    390
    118
    40
    Montreal
    Thanks for mentioning the cube, I was vaguely aware of that. Yes, Rockauto - probably picking at the border my self since I'm pretty close, have to check the costs though.
  3. Siward
    Siward Active Member
    314
    128
    Toronto
    Brake & Wheel Hub Tool Disc Brake Piston Tool Parts | RockAuto
    Only buy if it comes from same warehouse. Good luck shopping. You can get a similar cube from Canadian Tire or Princess Auto locally.
  4. andreimontreal
    390
    118
    40
    Montreal
    Aren't those clips supposed to be part of the pads kit? I bought some pads at Canadian Tire before this and they had them inside (off course, took those back when I decided to buy from rockauto).
    I'll probably get some banjo bolts too in that case - if there's so much rust I wouldn't be surprised to see those rusted as well. So you pretty much got the whole caliper in there - the bleeder valve was on it right?
  5. Mendel Leisk
    42,355
    For Toyota pads at least, the pads and shims are separate items. These are rear pad/shim part numbers, btw:
    I think ditto for the the pad end clips, the odd-shaped ones that push into the caliper mount bracket. Are your existing ones shot btw. They do rust out. They're easiest to remove with the rotor off.
    #25 Mendel Leisk, Oct 23, 2019
  6. andreimontreal
    390
    118
    40
    Montreal
    The V shaped clips, are something like this? Drag reduction?
  7. Siward
    314
    128
    Toronto
    Yes. Brake pads can come with brake hardware (which sometimes includes the V shaped clips). Look for "brake hardware included". It really depends on which one you buy:
    Some kits are bare boned brake pads which expect you to extract and reuse your old shims/hardware. In my case, I bought the Wagner ThermoQuiet Ceramic Pads QC1423 shown in the picture above. I plan to try a different brand next time as I have had a couple uneven wear on the outer pad. It may be different now that I have new caliper.
    #27 Siward, Oct 25, 2019
  8. Siward
    314
    128
    Toronto
    Some pads do not come with the "V" clip. Again, depends on which one you buy. The Prius has them on the rear:
  9. Siward
    314
    128
    Toronto
    I have never seen a caliper that didn't come with a bleeder valve. I would look for the bleeder screw on the pictures.
    It maybe however, missing the black rubber bleeder valve cover (I can't quite remember). Just bring your old one over if that's the case.
    #29 Siward, Oct 25, 2019
  10. andreimontreal
    390
    118
    40
    Montreal
    Yes, I've noticed that only the rear brakes seem to have those clips in the kits. Why is that? Why wouldn't this feature be installed in the front where it matters even more (or I would think that) ?
  11. Siward
    314
    128
    Toronto
    That's a Toyota design question. Who knows, it may be there to force the pads apart and prevent wear, but the rotor rotation force does this. It can be there to prevent vibration of the brake pads. Some aftermarket pads (such as Raybestos) tells you simply not to use them.
    In my opinion, they are pretty useless. I was tempted to remove them the last time I cleaned my brakes. I decided to leave them installed in the end.
  12. Mendel Leisk
    42,355
    The stock rear brakes have those v-shaped springs, but the fronts don't. Not sure why.
    Repair Manual brake info attached.
    #32 Mendel Leisk, Oct 25, 2019
  13. Siward
    314
    128
    Toronto
    The rear brakes have a pesky parking brake line. You can study the videos below:
    -- Removed using 14mm:
    -- This guy just cutoff the hose guide:
    andreimontreal and Mendel Leisk like this.
  14. Mendel Leisk
    42,355
    South Main Auto just keeps getting better, lol.
    Excellent demo of the caliper piston notches, and how it fits with the pad backing plate pin, btw.
    Video reminds me: attached is the Repair Manual brake bleed without Techstream procedure. Watch @NutzAboutBolts video too, pinned in third gen maintenance forum; he makes it look doable. :)
    #34 Mendel Leisk, Oct 25, 2019
  15. andreimontreal
    390
    118
    40
    Montreal
    I was gonna bleed as per ChrisFix vid. Will check that too when the time comes.
  16. andreimontreal
    390
    118
    40
    Montreal
    Speaking of manuals and diagrams, I'm trying to find out which parts I need for the hydraulic lines. The rear ones look rusted badly, the plastic is cracking on them. I see there is a front left and right specific, the rear has an outer that's the same on both sides (lower looks like it goes into the caliper), then after that I need the inner parts for rear left and right? That's six parts in total?
    But just as with any part, it looks like surface rust, so I wonder if it's worth replacing anything at all - especially in the front where it looks like it's a hose instead of the metal wrapped in plastic.
    #36 andreimontreal, Oct 25, 2019
  17. Mendel Leisk
    42,355
    Not sure, would just clean them but not replace. Paint the metal crimps on hose ends with boiled linseed, taking care to not spill over onto the rubber line, just in case.
  18. ChapmanF
    19,038
    I did have a brake line get rusty enough to leak ... not on a Prius, and the line was steel, about 25 years old.
    The leak was hard to find. What seemed to happen was the tube just got weak enough to kind of split, in a little hairline crack along the tube lengthwise. The brakes would feel pretty good unless you really stood on the pedal, and then it would go toward the floor. Only the highest pressures were enough to force the crack open and then spray out a little fan of 2000 psi fluid.
    I finally caught it by finding a spot that looked moist across from the brake line, pointing a video camera there, and then standing on the pedal. (With no part of me anywhere near that camera, 'cause 2000 psi fluid can spray through skin, and that's no joke.)
    So yeah, if the steel line is getting questionable, you would not be crazy to replace it, whether you go with Toyota's preformed coated-steel ones, or get a roll of cunifer and make some, which ought to be the last ones needed.
  19. Mendel Leisk
    42,355
    Huh: cunifer is a copper alloy.
