Rear Lift Gate Bellows R&R
Discussion in 'Gen 2 Prius Main Forum' started by tkc100, Jun 30, 2025.
  1. tkc100
    tkc100 Member
    92
    25
    Arizona
    I did not know what to entitle this post because I can't think of a good name for the part in question. Hence the attached PDF. I suppose it could be called a bellows.
    Are there any special concerns, methods or tricks for disconnecting one side of the bellows. I need to disconnect the vehicle side so that I can snake a wire into the lift gate.
    It seems simple enough, but if it simply pops out it doesn't do so easily.
    To anyone in the community that has approached this problem before I would appreciate your advice.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Here you go:
    SM-S936U ?
  3. Tombukt2
    Tombukt2 Senior Member
    13,844
    2,514
    Durham NC
    No you can pry that up and do whatever you want. No issues at all just put back wen done
  4. tkc100
    tkc100 Member
    92
    25
    Arizona
    Thanks!
    When it didn't come apart easily, thought I would ask to avoid one of those "OS" moments.
  5. ChapmanF
    18,996
    Have you reached above the headliner and tried pushing the grommet edges out from inside the car?
  6. tkc100
    tkc100 Member
    92
    25
    Arizona
    No i haven't done anything except make a half hearted attempt. I think the grommet has a wire reinforcement in it.
    It's 111 degrees out side right now.
    Will have to wait until in the morning as or before the sun comes up.
  7. Tombukt2
    13,844
    2,514
    Durham NC
    Squeeze like hale and pull up at either end but one end it comes up but it's in they're.
