Rear lower window cant be tinted
Discussion in 'Gen 2 Prius Accessories & Modifications' started by savingtheearth, Mar 31, 2006.
  1. savingtheearth
    savingtheearth Junior Member
    82
    LA
    Just had my windows tinted. The lower part of the rear window which is dark on the outside and light on the inside, cannot be tinted as it is plastic and not glass. When you get your windows tinted, from the inside half of the rear winodw will be tinted and the bottom half clear. How to resolve this issue?
    Thanks
  2. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    MY lower rear window is already dark enough. If you use the cargo shade to hide packages, you can't see them through the 'glass'.
    Maybe your car is different?...
  3. silentak1
    silentak1 Since 2005
    893
    28
    LA
    It's temperglass. It's glass. I had it tinted with 50% film, no problems.
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(savingtheearth @ Mar 31 2006, 12:19 PM) [snapback]233076[/snapback]</div>
    Take it back to your installer. It is clearly marked Toyota Temperglass. Several people have had it tinted with no problem.
  5. BMcGraw
    BMcGraw Member
    230
    Southern California
    It can't be tinted? I'd better run out and take mine off then. :rolleyes: Somebody's full of it. It is so glass. I think I'd tell them to finish the job while they're at it and do it for free since you had to make a return trip. B)
  6. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    I got mine tinted as well.
  7. H2OSkier
    H2OSkier Member
    276
    16
    Mine is tinted too :)
    Ken
  8. K5VMI
    K5VMI New Member
    Baton Rouge, LA
    Go back and get your lower window tinted. It's well worth it.
  9. darelldd
    6,057
    389
    Northern CA
    What does this mean? I know the lower glass you're talking about... but dark on outside and light on inside? It is tinted.... and is darker both ways.
    And of course it is glass, and not plastic. I had extra tint added to mine, certainly. You need to find yourself a real tint guy!
  10. ghostofjk
    ghostofjk New Member
    979
    The guy who tinted my windows offered to tint that one, but I declined as I thought it was dark enough. Now, with the upper window tinted, it (the upper) is only a little darker than the lower.
    Spank your tinter and make him stand in the corner.
  11. savingtheearth
    82
    LA
    Thanks
    I just left a message for my tint guy to tint it and that it is glass and not plastic. He didnt seem lazy. From the outside it doesnt make a difference- but looking from my rear view mirror there is a big color difference between the top and bottom of the rear glass. Although for visibility- the lower/untinted part is easier to see through. Now I am torn!!!
  12. KTPhil
    KTPhil Active Member
    1,379
    "Spank your tinter"
    PLEASE, NO! This is a FAMILY board!
