Rear Seat Light Install
Discussion in 'Prius c Accessories and Modifications' started by G-Echo, Feb 9, 2018.
  1. G-Echo
    G-Echo Junior Member
    Phoenix
    2018 Prius c
    My daughter likes to read in the back seat while we're driving so I had to install a light for her. I'm pretty good with fiberglass/composite fabrication so I decided to install a LED in the rear door sail and hard-wire it in for the driver to be able to adjust the level of the light.
    Here's the sail, LED light and switch that will be installed.
    Mounting hole cut and light wrapped in tape and hot glued into place to get the angle I needed.
    I used Duraglass to mount the light in place and shaped it the sprayed it with a high-build primer.
    Sail panel with the light and switch installed. I textured it and sprayed it with some black satin paint.
    Where I mounted the knob next to driver's seat and under the E-Brake...I utilized a 12V LED dimmer switch and modified it to meet my needs.
    Light at a low setting...
    Light at highest setting
    What the sail panel looks like.
    The longest part of the install, besides modifying the sail panel, was the wiring...it was a pain but I really like the way it come out and my daughter loves it. I'm not sure if I'll do the other side, but I'm sure one day I'll get bored and knock it out.
    52,863
    wow! that is impressive, well done!(y)
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    so you going to start selling them? lol
  4. G-Echo
    Phoenix
    2018 Prius c
    If I had a 3D printer and the know how, I definitely would since I think they'd be easier to make...unfortunately, my 'medium' is fiberglass and carbon fiber.
  5. Diemaster
    Diemaster Active Member
    302
    265
    so. cal
    what a nice father to give your daughter some wisdom and illumination .....pun intended. or if she's depressed you can always brighten up her day.
    G-Echo likes this.
  6. AndrewsPriusC
    AndrewsPriusC New Member
    San Francisco, CA
    2016 Prius c
    This is awesome, thanks for sharing. Great inspiration for the rest of us !
