Rear speakers or headunit?
Discussion in 'Prius v Main Forum' started by PriusHead05, Jan 18, 2023.
  1. PriusHead05
    PriusHead05 Member
    318
    2012 with 162k mi. Base stock radio/headunit and speakers. The other day, we noticed that both rear speakers were producing about 75% less volume than the front speakers. Its enough to make it sound like there is no sound coming from both rear speakers at all. All the speakers work, it just that the rear are at 75% less volume than the front. I played around with the balance and fade and all the speakers are fine, but still the rear are hardly producing any sound. I did put it back to center fade and balance. I have been told to replace the rear speakers because they are most likely gone bad, but here's what I don't understand. Could they both really have gone at once and they still sound fine, but at a reduced volume compared to the front? I'm thinking it's the headunit. What do you all think?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,030
    6,918
    Texas Hill Country
    Those speakers were like that from the factory. Common issue.
    To do it right you need an amp for the back with a speaker level input. I believe there is a crossover built into the head unit that limits the rear speakers to low frequencies which are rarely output by the head unit except occasionally on hd radio.
    With that said, some have swapped to a 2015-17 headunit but that requires some adapters. @gromittoo is the expert.
    #2 rjparker, Jan 18, 2023
    Air_Boss likes this.
  3. PriusHead05
    PriusHead05 Member
    318
    I'm thinking about swapping the headunit out for an Alpine. From the sounds of it, that would fix it? Because that's how it came from the factory (the speakers are not the problem?)
  4. rjparker
    11,030
    6,918
    Texas Hill Country
    You can always improve on the speakers, but fundamentally the issue is the head unit.
    The rear speakers are positioned down low and are somewhat muffled by the seats.
    The front dash and door speakers per side are paralleled. The rear speakers have their own outputs.
    You will lose Prius specific screens and functions, including some setups and hidden diagnostic screens. None of which are deal breakers. Not sure what happens when the head unit's network connection to the vehicle is lost. It may throw a code.
    If the existing head unit is a 57011 it will have an expansion box attached to the bottom which provides GPS, bluetooth and navigation.
    There are up to four antenna inputs and one proprietary rear camera input.
    If I recall correctly, some of the antenna inputs require adapters. I don't think you can retain the factoty rear camera function with an aftermarket radio.
    If it were me, I would consider the Toyota upgrade coming from a 2015 through 2017 v.
    Again, I would contact @gromittoo for his first-hand experience. I don't believe he monitors this forum on a regular basis.
    Finally, the low cost and full function upgrade might be an amp for the rear speakers.
    Rear view 57011
    #4 rjparker, Jan 18, 2023
    gromittoo likes this.
  5. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    The factory speakers are a total joke. Think old school clock radio cheap.
    Upgrading the speakers will improve the volume, even though the wires to the speakers are like 22 gauge. Will need an adapter kit to mount aftermarket speakers, as the factory speakers are riveted in place.
