Rear speakers volume adjustment
Discussion in 'Gen 3 Prius Audio and Electronics' started by ed@ny, Jul 3, 2010.
  1. ed@ny
    ed@ny New Member
    New York
    Hi all,
    Just purchased a Prius III a week ago, like it so far. But one thing I have not figured out is how to adjust the rear speakers volume. My Prius has a JBL system, the two front speaks are quite strong, but the rear ones are not. On my other car, Camry, the volume can be easily adjusted to make either the front or rear speakers loud / light / balanced. How to do this in Prius? I believe it must be capable of doing such a basic thing, right?
    Thanks,
    Ed
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    You can adjust the fade control, when listening to an audio input, by pressing the sound button, then adjusting as you like.
    More info in the manual. ;)
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Page 319 in the manual.
  4. fairfieldwizard
    fairfieldwizard New Member
    46
    Central Connecticut
    You will only be able to adjust this a little. There are other posts on this forum- common complaint with the JBL system- sounds great overall but rear door speaker volume is very low.
  5. Thai
    Thai Prius Neophyte
    1,197
    89
    This is what i have posted in the past about this intentional muting of the rear speakers:
  6. Craigmri
    Craigmri New Member
    134
    OK peeps, I'm a newbie here and I too noticed the rear speaker volume to be weak even if I was to fade all volume to the rear using the touch screen on the JBL. This is normal?
    Craig
