Rear spoiler, is it glued on?
Discussion in 'Gen 3 Prius Technical Discussion' started by Anthony, Oct 1, 2009.
  1. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Thanks Tideland. You solved the riddle of the day. :)
  2. Tideland Prius
    16,665
  3. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Again, I use the handholds on the inside- and it is not a two step process... Just reach up and pull down and let go about half way down. I don't like touching the emblem or painted surfaced because, if it's recently washed I don't want my fingerprints on them and if it needs a wash I don't want the dirt on me!
  4. Tideland Prius
    16,665
    Try it on a Gen 2.
  5. RobertCh
    RobertCh Junior Member
    SF Bay Area
    I was skeptical about that when I read it. Didn't think it'd work. But I just tried it and yeah it works great (at least on a gen3). Thanks bighouse!
  6. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Agreed -- the Gen 3 is easier to close than the Gen 2. I used the inside handle on both. I think on the Gen 2, I would have to give it a little shove from the outside at the end. The extra push isn't necessary with the Gen 3. I'm vertically challenged, by the way, and have no problem. Haven't caught my arm in it, either :p.
    I haven't noticed the rear spoiler wobbling -- but I haven't tried to wobble it either.
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I never found closing the hatch to be a problem - just reach up, give it a good tug, and don't forget to pull your arm out of the way. ;) Only tried the 2010 once or twice, but it did seem easier, plus it has inside handles both left and right.
    Oh yeah, this is about the spoiler - no, if it was glued on, it probably wouldn't wiggle. It would be awfully tricky to remove and replace, though.
  8. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    Pretty much no wiggle on my spoiler. Firmly attached, however it was done.
  9. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Very early in my G3, IV ownership, I read not to use the spoiler to close the hatch. I use the side handholds, and that works fine.
    A week or so ago I ran the car through an automatic car wash. I did not realize until too late that a rotating wheel device with multiple strips was passing over the hood and top. When it got to the rear, the spoler took a severe buffeting .... I was plenty worried. Thankfully, the spoler did not seem to be damaged ... but I will not take into such a car wash again.
