rear strut upgrades towing heavy loads
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Glen2007, Jun 10, 2021.
  1. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    I had the same problem I just used a spring compressor while it was on the car. Once I lowered it down there is like 2 inches of clearance between the cv shaft and the subframe. I believe in time the spring will compress slightly from wear and all should be fine. (y)
  2. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,694
    396
    2013 Prius Plug-in
    whaa cut... show pics. you know there are sub frame spacers available right?
    Prius Rising likes this.
  4. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    I did not take any pics of me applying the spring compressors and no I did not know there were spacers available. What I have works just fine as there is like 2 inches of clearance once the car is sitting back down on the wheel but by all means please post a link to said spacers if there is a better way I will certainly do it. (y)
  5. black_jmyntrn
    1,694
    396
    2013 Prius Plug-in
    here you go, Subframe Spacers for Lifted Toyota Prius
  6. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    SFO likes this.
  7. Garen
    Garen Junior Member
    Sherman Oaks
    2019 Prius
    Hello, I want to put these on my 05 gen 2. Will this be a option for me and do I need to purchase spacers too or I will be ok with just the complete struts assembly from eBay? Thank you for your help
  8. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    I went with the cheaper spacers from E-Bay and the Pontiac Vibe springs on mine. The spacers are nice and I am up like 5" from where it was with the spring/spacer combo but the passenger side cv axle touches the A-arm when jacked up off the ground. It is fine when lowered and I just completed a 10k mile trip with my build in November 2022 with no issues. The guy from Prius Overlanding said he was working on a-arm spacers to negate this problem. Good luck and feel free to ask any additional questions. (y)
    #28 Prius Rising, Jan 10, 2023
  9. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    I'm in like $600 or so on my build that 3,100 price tag for that air system seemed a bit much and where do you put the tank and compressor and all that? :whistle:
  10. Garen
    Garen Junior Member
    Sherman Oaks
    2019 Prius
    that is awesome. thanks for info.
  11. black_jmyntrn
    1,694
    396
    2013 Prius Plug-in
    New KYB all around and only the previous spec'd rear lifting springs we used, not the new spec's. We are thinking 2" strut topper lift in the front next for this one. with the build inside and cargo on the top is guesstimated additional 600lbs load with all the precious cargo.
  12. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Does anyone have part numbers for a Pontiac Vibe rear springs and shocks into a Gen2 Prius?
    Thanks in advance.
