Rear sway bar preference? Trd? Or Cusco?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Hawaiiprius, Jan 17, 2020.
  1. Hawaiiprius
    Hawaiiprius Junior Member
    Hello. What’s your choice on this modification? And why? Thanks
  2. PriusCamper
    PriusCamper Senior Member
    13,288
    5,370
    Pacific Northwest, USA
    Some basic machine shop tools like a drill press and a band saw and some grinding gear is all you need to make your own... Spending hundreds of dollars for a $30 chunk of Aluminum you can fabricate in less than an hour is a huge waste of money.
  3. tallprius
    tallprius Member
    62
    29
    texas
    Premium w/ Solar Cells
    Last year I got a OEM (sort of) sway bar on Toyota/scion dealer on Ebay, but it OEM for the scion xb part PTR11-52091 for about $200 dollars. It is painted red (the OEM prius is white) and had toyota end links included. Some sway-bars bolt right on without end links but i have read (here) that either bar itself or something back there breaks. result was the car handles better more stable and not a hard ride. The LLR tires are probably the next limiting factor.
    Hawaiiprius likes this.
  4. Hawaiiprius
    Is the sway bar aluminum? I thought they were made of steel?
  5. Hawaiiprius
    Thanks for the info. I’ll check it out.
  6. PriusCamper
    13,288
    5,370
    It depends which one you're referring to? I know of at least four potential locations you could weld in or bolt in steal or aluminum to make the car go around corners faster.
  7. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Most sway bars are made from steel. Typically after-market braces are made of aluminum.
    PriusCamper and Hawaiiprius like this.
  8. Hawaiiprius
    That’s what I thought also. Is there more improvement in handling with the sway bar or the upper strut brace for these cars?
  9. PriusCamper
    13,288
    5,370
    Yes... I'm told it's clearly noticeable. But you're still driving a Prius...
    Attila Fekete and Hawaiiprius like this.
  10. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  11. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    I drive my Pri like I drive my speed, fast.
    I couldn't tell you the difference between the brands but both will work by giving you more control of your car. It's the best performance mod for the $. Easy install too.
  12. PriusCamper
    13,288
    5,370
    And how do you "drive" your speed? Do you inject it into your veins or snort it, or smoke it?
  13. Greenteapri
    330
    387
    Cypress
    What dark and revealing psychopathy, camper. Best to have that checked.
    Mazdaspeed 6 to be exact. Otherwise
    D. None of the above.
    The TRD is white and looks great from behind.
  14. PriusCamper
    13,288
    5,370
    You're the one saying you like to drive speed... If you don't communicate clearly you get misinterpreted/misunderstood. That's the beauty of social media.
  15. Greenteapri
    330
    387
    Cypress
    CEO of thread-jacking @PriusCamper
    The TRD badge is nice, too.
