Rear tailgate windscreen not fitted properly 2016
Discussion in 'Newbie Forum' started by Philthunder, Jul 17, 2017.
  1. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    Gen 4. I noticed little brown dots appearing in the black glass around the drivers side (right) on the tailgate. Curious I watched them grow, "Can not be right" I thought. Along the top edge then down the bottom right corner, time to ask the dealer.
    Anyway it was not a priority, but after a good wash and brush up, while polishing around the glass edge near the top right I noticed that the glass moved. Not much but enough to see, and it rattled if moved fast. Ah could that be the noise coming from the back end? Shure was! Dealer time.
    Dealer looked, scratched his head, looked at another in for service. Yes dots in the right hand corner. Nothing on the new ones. "Bring it back for the once over". Back next week and Toyota had taken an interest. New screen.
    Back the next week and a new screen fitted, phone call late in the day. "Sorry new screen has a chip in it, will call tomorrow when another has been fitted".
    The next day new screen fitted all good. Dealer showed photos of the old screen and there was little sealant around the right hand side from the top one third right down to the bottom. He said there had been problems with another new model that they have replaced several front screens.
    So if you get little brown dots appearing about 2mm diameter spaced 100mm apart you now know what to do. Apparently they are designed to show that the sealant has been applied and cured properly, mine hadn't!
    Unfortunately I cannot find what happened to the photos.
    #1 Philthunder, Jul 17, 2017
    51,155
    thanks! someone else had rain leaking in through the rear glass. or maybe carwash.
    RCO likes this.
  3. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    Could be. My sealant went from a thick beak to almost nothing, easy place for water to get in. They have a clip fixed to the glass underneath out of sight, zip tied to the metal to stop the glass from fully detaching. Very strange!
    RCO likes this.
    51,155
    i think they were still struggling with the carbon fibre hatch at that point in production. that being said, there haven't been too many problems. the front windscreen may be more of an issue.
    RCO and CoastRider like this.
  5. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    You got that right, brother. Every one that cracks, I believe Toyota should replace those free of charge.
    RCO and bisco like this.
  6. Prodigyplace
    12,407
    11,682
    Central Virginia
    The Liftback does not have a carbon fiber hatch. You are thinking of the Prius PHV in the UK or the Prime in the US & Quebec.
    RCO likes this.
  7. Prodigyplace
    12,407
    11,682
    Central Virginia
    I think that was a Prius Prime / Prius PHV.
  8. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    Porous carbon fibre :p
  9. bisco
    51,155
    right, thanks!(y)
    Prodigyplace likes this.
