Rear View Camera
Discussion in 'Gen 3 Prius Audio and Electronics' started by raneyboo, Mar 18, 2014.
  1. our1vue
    our1vue Member
    313
    58
    NY
    06d,
    I didn't think it worked like that. On startup, the HU sends power to the camera and looks for a video signal (we'll
    ignore the orange wire for now :). If it sees a signal it knows a camera is there and when you put the car in reverse, it displays the signal. No signal on startup, no display of signal when car is put in reverse. That is what I think is stopping James4455 system from working. His camera is getting power from the brake lights which are off at startup.
    One prius owner just connected up the video wires and got power from the wiper motor and it worked. The down side is the camera is powered on when ever the car is on. There is a time limit for the camera check and I wonder if you turn the car on and quickly put it in rev if the HU would still be doing its check and see the camera signal.
  2. 06d
    06d Junior Member
    Bay area
    oh this is possible i was going off the theory of an aftermarket HU
  3. our1vue
    our1vue Member
    313
    58
    NY
    06d,
    Using an aftermarket HU takes all the fun (and grief) out of getting it to work :)
  4. chang50012
    chang50012 Junior Member
    16
    WA
    James4455,
    Sorry to hear that you are still having trouble to get the backup camera working.
    May I suggest You return and get refund from BestBuy for that camera and just get the "plug and play" kit. The one I got come with instruction and connector for the HU. As long as the tech could open some panel and put them back, they could do the work and without worry about where to get the 12v power for Camera.
  5. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    I got a quote from a shop that specializes is hybrids, mainly prius, it was 350.00 installed and that includes the camera from Toyota. That's if you have a touch screen LCD HU already. I was told by the sales person most options can be added elsewhere for about half of what the dealerships charge.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    Just curious to know if standard back-up camera on 2015 Prius Two can be modified to show video when the gear is in Drive. As all of you know, the Prius have very restricted rear view through the split glass on the back. It would be very nice to be able to check the rear view camera while you are driving.
  7. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Salamander_King likes this.
  8. Salamander_King
    11,024
    8,976
    New England
