Rear View Mirror Height
Discussion in 'Gen 4 Prius Main Forum' started by warpedlogic, Mar 19, 2018.
  1. warpedlogic
    warpedlogic Junior Member
    Orange County, CA
    I was reading through the manual and found the rear view mirror height can be adjusted. It doesn't say if it's for all rear view mirrors or just one of the available types. I tried, but couldn't get it to budge and I don't want to break the glass. Has anyone successfully raised or lowered the mirror? If so, how high does it go up?
  2. Prodigyplace
    12,711
    11,848
    Central Virginia
    IS this what you are referring to?
  3. warpedlogic
    Orange County, CA
    That's it. I can't get it to move up, and it's quite low in it's current position. And apparently it does say for which rear view mirror. lol. Good thing that's the one I have.
  4. Prodigyplace
    12,711
    11,848
    Central Virginia
    I have the same car but I have not needed or tried to move the mirror up & down.
    Perhaps I can check later.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I just went and tried it - yes, it does move - there is a goose-neck at each end of the joiner between the mirror and the mount:
    But it makes marginal difference - if you had a short person or a tall person - they might get a bigger range of motion. But, for me - remaining the same height, it did little.
  6. warpedlogic
    Orange County, CA
    alanclarkeau, I thought it was an up/down motion, so this helps a lot. Thank you!
    alanclarkeau likes this.
  7. warpedlogic
    Orange County, CA
    I got around to doing this last night, and it actually made a huge difference. I can now see when making a right, and when coming around a curve at work. Thanks again for looking at it!
    pilotgrrl, RCO and Prodigyplace like this.
  8. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Thanks, Alan! Now I'm not getting blinded by headlights behind me anymore. And yes, I need to read the manual again.
    alanclarkeau and Prodigyplace like this.
  9. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Reading the manual often doesn't help me. By the time I get to the end of that tome I've forgotten what was at the beginning! ;)
    600 pages? Really, Toyota?
    pilotgrrl, RCO and Mendel Leisk like this.
  10. Prodigyplace
    12,711
    11,848
    Central Virginia
    pdf & search is your friend ;)
    UltraJetRefill and pilotgrrl like this.
  11. padroo
    padroo Senior Member
    2,763
    2,253
    I have had trouble with other car mirrors creating a blind spot when I glanced to my right. It's hard to believe a full size car could hide behind there. I finally adjusted mine and it did take some effort.
