Rear View Mirror - Limited Vision
Discussion in 'Gen 5 Prius Main Forum' started by Sue Case, Dec 26, 2022.
  1. Tideland Prius
    16,668
    I find it funny that for years (decades), reviewers complained about the split window and how it made visibility worse. When I watched the Gen 5 launch videos, a number of reviewers pointed out that now visibility is worse because the lower rear window is no longer there.
    Damned if you do, damned if you don't.
  2. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Not denying that. However, a rear view mirror isn't standard...and we shouldn't have to pay a premium to get decent visibility. (y)
    daisy555 likes this.
  3. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    Good point. When I was shopping around for cars in 2020 I only test drove one standard Prius, and I didn’t like the split view / spoiler situation at all, so I’m happy to see it go. I think it’s a bit early to assume rear visibility will be an issue with the new model, but I would get a third party dash cam mirror regardless for the LE (which would be the only model I’d be interested in). IMO Everyone should have a couple dash cams these days, and I like that having the front cam integrated with the mirror keeps it out of the way. I mount my rear cam inside and keep the hatch window clean, but I would probably put it outside if I had a fancy one with wipers.
    52,773
    well, the split window was bad, how could removal of the lower window be better?
  5. Perpetual Waffle
    96
    120
    Wisconsin
    2023 Prius
    XLE AWD-e
    I loved the split window, personally. Blocked annoying headlights from glaring into my rear-view mirror at night.
    daisy555 and Trollbait like this.
  6. Trollbait
    12,803
    You are completely free to remove the headrests or order low profile ones from Europe. But what happens if you have rear passengers without the US spec restraints in place, and you are rear ended?
    I only look out the back window before moving. Since the Camry with back up camera, which is mandatory, I'm watching the dash screen with wider view of the rear that covers the blind spot of the trunk/rear panel.
    The digital mirror requires a second camera installed in the back. If not required, manufacturers would be skipping on the first.
    I don't think the washers are required; rear wipers aren't. Haven't had the back up camera totally obstructed yet.
    Many people didn't know how to adjust the rear mirror right to allow visibility out both windows.
    Tideland Prius likes this.
  7. Sue Case
    Sue Case Junior Member
    89
    44
    Maryland
    2023 Prius Prime
    So we're in a world now where the wealthy can afford more safety features (upgraded digital mirror) where those who count pennies run the risk of increased "back-up accidents" using standard rearview mirror. Just saying when come to better driving visibility (front, back and sides) all owners of the 2023 Prius/Prime should have benefit (at no extra cost) to digital review mirror.
  8. Tideland Prius
    16,668
    Hasn't that always been the case?
    For the Gen 2, VSC and side/side curtain airbags were optional on higher packages.
    On Gen 3, PCS was available on the V/Five with AT Package
    On the Gen 4 for 2016, TSS-P was optional on the base model.
  9. bisco
    52,773
    other than federal requirements, we've always been in that world.
    personally, i would prefer the option of opting out
  10. Trollbait
    12,803
    You use your rear view mirror to back up? That's for doing quick checks on what's behind you while driving forward. No back up camera, you should be turning to look out the back window when reversing.
    The digital mirror showed up in minivans and large SUVs because there was more likely hood of something in the car blocking the view from the mirror. It uses a camera positioned higher up than the back up camera to give a view similar to what you would get when using the mirror. In some cars, the screen for it is the mirror.
    The higher trim Prius are getting it to make up for the loss of the rear wiper. It might show a little more area than the mirror could show, but most of its advantage is that the view won't have people's heads, head rests, of c pillars in the way. Other than that, it won't be of much more help than the mirror itself. When reversing, the back up camera's wider angle will show more to the sides, and the more down ward view the edge of your bumper.
    As for paying more for safety features, the only reason the automotive world got three point safety belts as soon as it did is because the people at Volvo were kind enough to open up the patents as soon as they filed them. Most of the others would keep them exclusive while charging extra for them.
    daisy555 and Tideland Prius like this.
  11. TGTGUUD
    TGTGUUD Member
    99
    76
    San Francisco
    2024 Prius
    Don’t worry too much.
    With the camera and sensors you won’t need the mirror for reversing. Almost impossible for you to back into anyone or any object. The car will brake for you.
    The mirror in a Prius is useful when someone is tailgating you so you can move to the right lane. Now that the new Prius is much faster it will be less needed anyways.
  12. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Are you thinking the digital camera might not be a necessary add on? I’ve never used one. I have no trouble seeing out the back of my Gen 2. I test drove a Gen 4 and rear view seemed more challenging but it was a brief test drive.
  13. bisco
    52,773
    my car goes plenty fast to keep up with traffic. i only move to the right lane if i am intentionally driving slower than the pack
  14. farmecologist
    1,960
    1,801
    Southern MN
    Uhh...all models do have the backup camera standard. So there should be zero issues when doing "backing up" activities.
    The issue is supposedly poor rear visibility when in traffic, switching lanes, etc... (y) However, I still think folks here like to debate things that very well may not be an issue ( including me ). Let's wait and see.
  15. TGTGUUD
    TGTGUUD Member
    99
    76
    San Francisco
    2024 Prius
    For me a digital mirror is nice to have but not necessary at all. I am used to relying on camera, sensors for reversing and it never failed me. The auto braking has saved my bumper many times. I only need the mirror to see how close cars are behind me and I think a regular mirror in the lower trims will do just fine.
    Plus, having a digital mirror does require your eyes to refocus to a much nearer distance while a regular mirror does not. If that is a concern.
  16. daisy555
    1,729
    716
    CT
    Thank you! I’m trying to picture what happens when trying to back up in a tight spot. The sensor must accommodate for this.
  17. Trollbait
    12,803
    The warning will scream at you. Can't say how the rear auto braking will behave, but I can turn it off in the Subaru. Same with the warning if it gets real annoying.
  18. Tideland Prius
    16,668
    Auto brake is only if the car is equipped with ICS. (Unless you’re talking about backing out of a spot, then that’s RCTB and radar-based)
  19. Richard III
    Richard III Junior Member
    Lexington, KY 40502
    2023 Prius
    XLE AWD-e
    But you can remove them
