Rear View Mirror Sensor Question
Discussion in 'Gen 2 Prius Main Forum' started by ZitterZap, Mar 26, 2012.
  1. ZitterZap
    ZitterZap Member
    76
    28
    Houston, TX
    What is this sensor in the rear view mirror for?
    My rear view mirror looks exactly the same. Should it be covered with some transparent plastic or something? or is it allright
  2. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    auto-dimming sensor...to dim or tint the mirror when bright lights from cars behind u approach?
  3. cnschult
    cnschult Active Member
    772
    95
    Michigan
    that auto dimmer can be turned on or off with the 2 buttons on the right of it.
    if its auto-dimming is it still called electrochromatic? because the rearview of our rx turned all white lights to green and definitely disorienting until you are used to it.
