Rear Washer Pump Change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 1s2k, Nov 16, 2021.
  1. 1s2k
    1s2k Junior Member
    After troubleshooting, it would seem that I'm in need of replacing my rear washer pump (front works fine, no pump noise at all when rear is activated). Would anyone have instructions for this and are willing to share? There was another thread with a copy of the relevant repair manual section for this, but I can't seem to find it again. Thanks.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Pretty easy 2 little pumps plugged into the bottom of the reservoir.
    One is front other is rear, already replaced 2 on mine over the years
    So suggest you replace both pumps while In there. They just unplug from the bottle. Pull right out.
    Can’t remember which is which but easy to find out.just unplug each one till the front no longer works then label that connector and water line.
  3. 1s2k
    1s2k Junior Member
    Thanks for the info. Did you have to remove anything else to get access to the pumps? I can see the pumps, but didn't try to remove them yet. Also, are the front and rear pumps the same part # ? One site seems to show only 1 part for both front and rear, but another shows different ones.
  4. edthefox5
    10,096
    4,837
    Clearwater, Florida
    It’s tight in there as I remember as the cabling had no slack but doable. and it’s really easy to swap them around as I made that mistake.so keep track of which power plug controls which hose.
    Same motor for front and back.
    1s2k likes this.
  5. 1s2k
    1s2k Junior Member
    Just an FYI for anyone else that needs to replace their washer pumps. Although the front and rear pumps are the same, mine were different in the form of a slightly different connector. I had to trim a little bit of the plastic on the connector housing on the washer pump for me to install the rear one. When I looked up the part number from Toyota, they showed different part numbers. Not a big deal, it took all of 2 minutes for me to remove the extra plastic with wire cutters.
    edthefox5 likes this.
